Question about 3M X55i Multimedia Projector
How do i access the filter on the 3m x55i projector???? Also message on screen "check air flow" is this because the filter needs cleaning????
JustAskMe
  • 29 Answers
SOURCE: Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
Posted on May 05, 2007
exspert
  • 55 Answers
SOURCE: Check Air Flow
ok " sounds like you have a bad heat sensor , it will have to be replaced.
Posted on Jan 21, 2008
SOURCE: Resetting the air filter timer
Highlight filter time in menu then press RESET button on remote for min 3s to bring up menu. then up arrow to reset.
Hope this helps.
Posted on Jan 22, 2008
  • 105 Answers
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Posted on Apr 24, 2008
SOURCE: Displayed massege to check air flow
With most projectors there is a foam air filter behind a grill that is the opening to the cooling channels. A fan ensures air flow to cool the lamp, etc. This filter prevents dust from gumming up the works (and depending on design) may prevent dust getting into the optics. As the filter gets dirty it gradually cuts off the air and at some point a protective circuit kicks in and turns off the lamp.
If the projector is on you will feel a stream of hot air coming out of the exit vent. Projectors vary in terms of amount of air flow, so its difficult to define what is normal for a specific model. However, you can simply hold a hand in front of the vent and see if there is air flow (It will be hot air so, careful). If there is a "good" stream of air things are fine, but if only a very light flow is felt the filter may be dirty.
If the filter has not been cleaned or replaced recently make sure the projector is turned off and cooled down then take off the inlet cover and remove the filter. Clean or replace per the instructions for the projector (and periodically as defined .. but taking into account the operating conditions). Once cleaned turn on the projector and feel the "normal" air current for future reference.
Heat is one of the major causes of projector failure, so make sure cooling vents (inlet and outlet) are not obstructed and filters are kept clean
Posted on May 19, 2008
Clean filter air
Most projectors use cleanable - not replaceable filters. Just remove it, wash it out, dry it and re-install.
Nov 13, 2013 | 3M MP 8745 Multimedia Projector
Cek air flow
I don't fully understand your question, however air flow issues in projectors are usually caused by clogged air intakes or filters. The remedy is usually to just remove the lamp, and blow the unit out with an air compressor. Canned air won't work, as there's not enough pressure.
Apr 29, 2013 | 3M X95 Projector
After 2 mins on the bulb goes out
Need to change bulb and reset the lamp timer. When was the last time you clean the air vent filter. Clean it and reset the air vent filter cleaning timer
Aug 10, 2010 | 3M EP7630LK Projector Lamp for MP7630,...
Won't display a picture. thank you....
get it to a service as soon as possible
Mar 23, 2010 | 3M X55i Multimedia Projector
3M MP7640i Personal Projector lamp wont light
it's the vents and the passage to the blower.
Dec 24, 2009 | 3M MP 7640i Multimedia Projector
How we can clean airfilter because message is appearing regarding clean your air filter
check in the menu to see if there is a filter timer that you can reset. if so, reset it. if not, there is an air flow sensor on the projector that will send that message if the air flow is decreased so the projector does not overheat. find the filter and remove it. blow it out with canned air and blow out the projector as well. replace the filter and enjoy!
Nov 05, 2009 | 3M X50 Multimedia Projector
Air Filter and reset the timer settings
go into the menu. it should be in the same menu as the lamp timer. as for cleaning the filter, use canned air.
May 18, 2009 | 3M MP 7750 Multimedia Projector
Problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Mar 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
My projector displays a message called ''check the air flow''. what can i do to remove that message?
Check Air Flow means that the heat sensor is activated. This message means that the air around the projector is not circulating well... causing the heat. Check that the projector has at least 2 ft free air around it. Also, make sure that the filter is cleaned.
Hope this helps!
Check air flow
You need to clean the filters. When the filters collect alot of dust on them, they block the airflow to the internal parts of the projector and can cause the bulb to blow due to the temperature getting to hot.
Oct 10, 2006 | Hitachi CP-X250 Multimedia Projector
3M X55i Multimedia Projector Logo
231 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
