I need a RF Modulator for a VocoPro Bravo II 160w Karaoke Amp
  • 323 Answers
System will not turn on, but I can plug another device into the external ac power plug and that device turns on. What could be the problem?
The problem could be with your power adapter in which case it will be fairly easily solved. If there is another device with a similar power adapter, check that. If the power adapter is fine, then you need to call the customer service guys for your Karaoke System.
Aug 30, 2015 | Vocopro GIGSTAR-PRO-II Professional...
How do I reset error code SC548
25685181-yl5nsd0dwyytd1n2wv4v20hl-5-0.jpg OR
Sponsored Link Shop Bulk Wire & Cable
Network, Telephone, Coax & A/V. Quantity Discounts & Same Day Ship!
showmecables.com/Bulk-Cable STEP 1 Purchase the RF modulator at an electronics store. The modulator is used to connect your older television to cable.
STEP 2 Plug the RF modulator in a power outlet near your television. It is best to plug it near the television to allow for easy access.
STEP 3 Connect your television to the RF modulator by inserting the one-prong cord that is on back of your television. Insert the cord in the slot on the modulator that reads, "To TV." On older televisions, this cord is the only cord in the back.
STEP 4 Connect one end of the white one-prong cable to the cable box and the other end in the RF modulator. Connect it into the modulator in the slot the reads, "ANT IN." Usually, the cables are provided by the cable company--the technician uses them upon installation. This particular cable may run along the side of the wall to your cable box.
STEP 5 Turn on the cable box and the television set. Everything should be working properly. On the RF modulator, choose the channel for the television (either channel 3 or 4). The modulator turns on when you plug it in.
May 08, 2015 | Office Equipment & Supplies
CD DRAWRER KEEPS OPENING AND CLOSING ON ITS OWN WHEN POWER IS ON
switch is stuck. Clean mechanism with can of air to remove offending material.
Apr 24, 2013 | Vocopro Bravo Pro Karaoke System
I have a rf modulator i dont no where any thing goes i tryed i just dont understand it i just brought a dvd and vhs to gether
alot of DVD/VHS combos have a built in RF modulator. Look for a coax (screw threads) output on the unit and it should be labeld either DVD/VHS OUT or just VHS OUT. If it does not have a combo out then you will need to use the seperate RF modulator.
Your combo unit should have a set of yellow red and white jacks that are labeled DVD & VHS OUT. Connect these yellow red and white to the yellow red and white on your RF modulator, then connect the coax (screw threads) out on the RF modulator to the coax jack on the back of your TV. There is also typically a swich for channel 3 or 4 on the RF Modulator, make sure you TV is on which ever channel you have that switch set to. If your RF modulator has a power light on it, it will usually not come on until your DVD/VHS is sending a signal through it and it is connected properly.
If you have an antenna or cable box, your RF moudulator should have an Antenna or Cable input jack on it that you can use.
May 05, 2011 | Magnavox DV220MW9 DVD Player VCR
I picked up a vocopro karaoke machine at a yard sale and the echo makes a loud hum also i need a owners manual and remote where can i get help with this. model#890G thank you
Hello. For the manual and remote your best option is to search online. As far as the echo goes, this is just a cheap microphone with a cheap system. It will not go away unless you turn the volume down on the system. If you want to put good money down on a nice SHURE brand microphone it will definitly help with the echo, however it will not make the system any better.
Apr 17, 2011 | Vocopro DVD-Duet Multi-Format Karaoke...
I trying to hook up an old record player to my Vocopro karaoke machine & I can't get any sound. What cables & where do I hook them
the record player should have a 2 sets of wires (one for power) and the other for left/right sound........you may need an adapter for this if there is no RCA plug in (if there is plug in AUX)
Aug 08, 2010 | Audio Players & Recorders
I need a channel slider for a vocopro mixer KJ7000
various types are avail at mouser and digi-key .com. google them -check their catalogue and search under potentiometer.verify value,physical dimension and shaft length.
Mar 03, 2010 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
I need a schematic for the vocopro entertaner model no HKH000011
You might try emailing the service centers listed here and see if you can get lucky:http://www.vocopro.com/servicecenter.php
Jan 23, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
My receiver is reading NO DISC it is a vocopro karaoke player/receiver model # DKP-10G
First, the player does not support DVDs or MP3 discs.
Try two things:
#1:
Unplug from outlet and Turn ON player (while unplugged).
Plug back in and try to use the CD.
#2:
Obtain a CD laser lens cleaner from Radio Shack ($13). It is an audio CD with a row of brushes and does not use chemicals
Oct 16, 2009 | Vocopro DKP-10G
 Grubhead
Grubhead
