Question about Carrier 38CKC036 Air Conditioner
MODEL # CARRIER 38XD124300
The condenser fan runs backwards,
    Problem Solver:
  • 11 Answers
YOU COULD HAVE A BAD RUN CAPACITOR. UNFORTUNITALY THERE UNITE USE A DUAL PURPOSE CAPACITIOR. 40 UFD FOR THE COMPRESSOR AND 4 OR 5 UFD FOR THE FAN. SOMETIMES WHEN THE 4 OR 5 UFD CAPACITOR GOES BAD THE FAN CAN RUN BACKWARDS AND MORE SLOWLY. TRY SHUTTING THE UNIT DOWN AT THE DISCONNECT WAIT 5 MINUTES AND WHEN YOU RESTORE POWER USE A SCREWDRIVER TO GIVE THE FAN A PUSH IN THE CORRECT DIRECTION. IF IT DOES RUN IN THE CORRECT DIRECTION, TRY REPLACING THE CAPACITOR.
Posted on Jun 23, 2010
    Scholar:
  • 149 Answers
Sounds like you had a condenser fan replaced ok you just have verify if the fan is a reversible one there is like a plug type connector on top of fan all you have to do is swap the position of the plug ex. if black / white to white/black that changes the rotation. check against the diagram it should be for the CCW position.
Posted on Apr 21, 2008
My son has a noisy condenser fan on the carrier condensing unit, model is a BRC060360 and Im puzzled on this unit seer rating, any ideas? Also looking for a budget condenser fan for it?
Condenser fans are usually not very expensive, so I suggest you go to a carrier dealer and buy one as a spare part. Have you check that the fan is clean and none of the blades are damaged.
May 19, 2016 | Carrier Heating & Cooling
When the heater is on, should the fan outside on top of the unit also be working along with the blower from the heater ? When the heater is off, cold air is comming from the vent's, can I cover the
No. This is strictly a gas package unit, not a heat pump. the condenser fan motor should NOT run when their is a call for heat from the thermostat. The condenser fan only runs with the compressor on a call for cooling. Hopefully the compressor is not running @ the same time, but if it is, it would make sense that the contactor for the compressor & condenser fan motor is stuck closed OR the low voltage cooling wires are shorted straight to a 24Volt control wire.
Jan 15, 2015 | Carrier Heating & Cooling
I have a carrier Day & Night a/c - heater unit. the model # 591ANX0480000ACAA, 208/230 volts. my blower fan stays on continuously, even after turning the thermostat off. the condenser fan does not come on...
If the blower fan in the furnace won't turn off, there is a tripped/blown limit. It's a safety. As for your condenser fan it could be a run cap or motor. Do yourself a favor and have a licensed HVAC contractor take a look. Find a NATE certified or ACCA member. You will find a much better more qualified contractor.
Sep 23, 2013 | Carrier Packaged A/c 3 Ton 13 Seer And...
Fan motor on Carrier inside runs backwards
Sometimes a motor can start to run backwards... on an indoor fan it is usually because the air inside for some reason started the fan backwards while it was off and then when power is applied it continues to run backwards... once this happens the fan is ruined and it often will not atrt the right way even after the air problem is solved...
You will need to replace the motor and see if you can figure out why there was reversed air flow in your system...
heatman101
Aug 21, 2010 | Carrier 38CKC036 Air Conditioner
Condenser Fan and Compressor not turning on.
Are you sure you have high voltage going to the unit? One wire from fan lands on top left of contactor, the other two go to C and Fan on capacitor. Manually push in contactor, if no fan than no high voltage.
Jun 05, 2017 | Carrier 38CKC060 Air Conditioner
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
The condenser fan for carrier xarios 300 is not
there is a run capacitor is probably bad.
you can purchase a replacement one from slakey brothers. However the capacitor will still have a charge after the power and wires are removed. after turning off the breaker use a long bladed screw driver and ground the electrical leads to discharge the capacitor before removing. take it with you to the supply house along with the model and serial number of the condensing unit.
Apr 15, 2010 | Carrier Heating & Cooling
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
Central Air Conditioner
Turn the power to the indoor unit off. Remove the cover where the fan is. Feel the motor of the fan. If it is very hot the bearings have likely gone out. If the fan is cool to the touch I would call a service company because you likely have an electrical problem that will require some training to solve.
Jul 09, 2008 | Carrier 38CKC042 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
322 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
