Question about Kenmore Dryers
The turned the drum the wrong way when cleaning and it now goes both ways and won't turn on at all. Fixable? How? Where can I get a manual? The dryer is 21 years old
    Champion:
  • 200 Answers
Most likely the belt just came off
I did the same thing about 10 years ago...lol....don't feel bad
Posted on Jul 16, 2010
Kenmore 81142 drum no turn
This dryer is built by westinghouse which is now owned by electrolux. The drum rides on a rear center bearing and a set of plastic glides on the front. Common things that goes wrong are missing glides, broken belt, and broken center bearing. To get inside the machine you pop the top. Get the front off, then remove the drum. MY PICTORIAL AND SERVICE MANUAL
Jun 18, 2012 | Kenmore Dryers
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
The dryer drum does not rotate at all. The dryer itself will "click" on when I push the start button and you can hear the dryer and feel the heat but the drum won't move. We took the entire...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Dryers
I HAVE A TUMBLE DRYER BECKO DRVS62W THE BELT HAS SNAPPED HOW DO I REPLACE IT. THE DRUM DOES NOT ROTATE MANUALLY IS THIS ANOTHER PROBLEM OR WILL THE DRUM ROTATE ONCE THE BELT HAS BEEN REPLACED.
If this is an electric tumble dryer,
the way to replace the belt is from the rear of the machine,
remove all the screws on the rear silver panel, which gives you access to the internals of the dryer.
And yes the drum wont turn properly if the belt is broken.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Dryers
We were turning our drum and heard a loud pop sound; plus the clothes hadn't gotten dry.. the lights and everthing shows up but the dryer won't start up now
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'';
Jun 13, 2011 | Samsung Dryers
Drum turns but no Heat problem!!
Brian, if the glow ignitor comes on for a minute clicks and goes off then you need valve coils. if no glow at all could be ignitor or thermal fuse.
Jun 27, 2010 | Whirlpool LGR7646E Dryer
Push start & i get buzz noise. dryer does not start
This is most likely a faulty centrifugal start switch in the motor.
It may just be stuck, or it may have burned contacts -- all of which are fixable with emery boards, WD-40, toothbrush, electrical contact cleaner spray... If a spring is broken in the switch, it'll probably need replacing.
Charlie
Aug 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
