Question about Car Audio & Video
Sub not hitting constantly
I have a kicker solobarik L5 and a zx 400.1 kicker amp. I have a stock radio without any rca outputs so I had to hook up a rca line adapter. The sub hits sometimes. It is always on. I can see the sub working but as I push the gas, speed up, slow down, idle and push the clutch in it gives me different levels of hit.Sometimes it slams to its potential, but the next second it wont it will only be very light. Any help
  • 121 Answers
The big speakers have wires from the frame to the voice coil. After longer use at higher volumes (or longer travel), the wire can fracture, and make contact only some of the time..line on a bounce or knock.
Posted on Apr 20, 2008
Kicker 12L5 blew from a kicker zx750.1
MY BEST GUESS FROM WHAT YOU HAVE SAID IS THAT THE BOX WAS TO SMALL. BUT YOU ARE OVERPOWERING THE SUB RUNNING IT AT 2 OHMS ON A 750 WATT AMP WITH A SUB THAT IS ONLY RATED FOR 600. NO MATTER HOW FAR YOU TURN YOUR SETTINGS DOWN, YOUR STILL PUSHING TO MUCH POWER FOR THE SUB TO HANDLE. IT IS ONLY RATED 600 WATTS FOR A REASON. ESPECIALLY IF YOU LISTEN TO MUSIC THAT HAS A REAL LOW END AND THEN A HARD HIT. REMEMBER A HARD HIT WILL SPIKE YOUR AMPS OUTPUT THEREFORE PUSHING MORE WATTAGE TO THE SUB.
Nov 19, 2013 | Kicker Car Audio & Video
So I have the first kickers that came out the 15 will a 800 watt amp push um without eather blowin out
If you are referring to the Kicker L5 solo-baric subwoofer, then an 800 watt peak amp will not blow even one of those subs. The L5 is capable of handling 1000 watts peak and 500 wrms. An 800 watt peak amp will usually have around 400 wrms. Underpowering the subwoofer will not hurt the amp or the sub(s).
Mar 07, 2011 | Car Audio & Video
Factory radio in 2010 honda crv
You will have to pull out the head unit and see if there is a blue remote wire for am and rca audio output jacks that go to amp. I highly doubt it. Usually you have to get an aftermarket deck
Jul 27, 2010 | Kicker Car Audio & Video
Can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards robotek
Jan 19, 2010 | Kicker Solo-Baric S12L5 Car Subwoofer
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Yes i was wondering what would be the best way to wire my system. i have to kicker L5 4 ohm 10in subs and one kicker 1000 watt mano amp. what wolud be the way to get the best bass out as possible.
Hello eaglepower_2,
Well, to get the maximum power from the amp, you really need a 2ω load. Unfortunately, you cannot get that from 2 L5's with 4ω voice coils. You can get either 1ω which will burn your amp up, or you can get 4ω, and your amp will put about 500 watts RMS into that load.
To get the most from your amp, you really needed the L5's with 2ω voice coils. That way, you could run the voice coils in series and the subs in parallel, resulting in a 2ω load, exactly what your amp likes. If you can exchange them for the 2ω model, I would.
Here's the link to Kicker's manual for the ZX-1000.
http://www.kicker.com/sites/default/files/2008%20ZX%201000%201500%202500-1%20e01%20web.pdf
Hope this helps.
Apr 07, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Subs not as loud as they should be plz help
RCA output level and speaker level output have different voltages and currents. The problem you are describing is common to folks trying to connect an OEM dash unit to an aftermarket amp. If your amp has speaker level inputs, try wiring to those......best bet..buy a new head unit, it'll sound better...louder and cleaner.
Mar 11, 2009 | Kicker IX404 Car Audio Amplifier
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
Aug 24, 2008 | Kenwood KAC-9102D Car Audio Amplifier
How to install kenwood kac-9102d in 2006 acura rsx
My recommendation is to get a line level converter. Go to a car audio shop or even best buy and specifically ask for a line level converter. It will have speaker wires in and RCAs out. Connect the speaker wires to the sub woofer speaker wires and then you will have the RCAs to run to your amp. I hope this helped.
-Andrew Hawkins
Aug 24, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
123 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
