Question about Whirlpool Gold GW399LXU Gas Range
Whirlpool Self Cleaning oven error code
I used my self cleaning oven and afterward there is an error code E1 F5
  • Whirlpool Master
  • 43,501 Answers
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Jul 18, 2010
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Why won't the oven door lock to start the self cleaning? The door appears to be shut all the way. After hit start, this code appears E1 F5
According to the Whirlpool website, the self-cleaning latch may be interfering with the door, though this would be indicated by an "E0 F5" error code. If that's the case, Whirlpool recommends the following:
1) Press "Stop/Clear" to clear your display.
2) According to Whirlpool, there should be a door switch plunger in the upper right corner of the oven front. Press and hold this so that the door latch will unlock.
However, if it is indeed "E1 F5" (or any other number with those letters in the code), Whirlpool recommends calling an appliance technician.
http://whirlpool.custhelp.com/app/answers/detail/a_id/319/kw/error%20code
Feb 28, 2011 | Whirlpool Kitchen Ranges
Trying to selfclean oven and getting error code E1 F5. What does that mean?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 20, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to self-clean...code F5 and E1 pops up...whats wrong?
heatman101
Jan 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gold Self-Cleaning Oven Error Message: E1 F5. What does it mean and can I fix it?
E1-F5 means the self clean latch will not lock.
Try pressing down any key and hold for 1 minute, see if this clears it. If not you will most likely need the latch switch replacing.
Dec 20, 2010 | Ovens
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning feature
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.FGRT%$^
Jan 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool accu bake oven door locked after self cleaning
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^YRG
Apr 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
E1 F5 error message when try to activate the self clean
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning code error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&*^Y
Nov 22, 2008 | Whirlpool RBS305PD Electric Single Oven
Whirlpool Gold GW399LXU Gas Range Logo
557 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
