Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Fridge not working
I moved from my house to another house i moved to plugged it in the new house and it does not come on. It was standing upright only layed down to get through the front door. The fridge was working when i unplugged it from the old house now it does not is there a reset switch.
    President:
  • 567 Answers
Hi welcome to Fixya, you should plug it into a different wall outlet because the current wall outlet may not be working.If the wall outlet is working fine the the problem is with either the power cord or the fridge motor, you would need to check them one at a time.
Posted on Jul 15, 2010
  • psychojeremy Jul 15, 2010
    the outlet wrks the old fridge was plugged in there and it worked
  • Hilton Bristol Jul 15, 2010
    This mean the problem is with your fridge power cord gone bad or the motor stop working suddenly, you should get it check soon as possible.
Am moving an Admial fridge. Can I lay on side or front? How long after moving and standing up before I can plug in?
best bet is not to lie it down. i think if its upright at least 24 hours it might be ok but i wouldnt count on that.
Apr 19, 2017 | Refrigerators
We moved an Amana Fridge on it's side...how long should we wait before plugging it back in?
Anything with a compressor in it should always be left for 24 hours standing upright then you can plug it in
Mar 26, 2012 | Amana ABB1927DE Bottom Freezer...
Hi - I have to move a Daewoo upright fridge/freezer. It is too high to stand upright in my van, can it be laid on its side? Thanks
Yes, it can be laid on its side but when you get it to its location, stand it up and DO NOT plug it in for a few days to let the compressor oil run back down out of the system. After that everything will be fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 01, 2010 | Refrigerators
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
Just moved a Kenmore 15 upright freezer. Plugged it in and the motor does not come on.
IT MAY SOUND FUNNY BUT STAND THE FRIDGE ON ITS END FOR THE GASES TOCLEAR.LEAVE UNPLUGGED WHILE ON ITS END FOR ABOUT 2/3DAYS THEN STAND UPRIGHT AND PLUG BACK IN THIS MAY NOW WORK..ROB.
Aug 29, 2010 | Kenmore Freezers
Whent it was moved to my new house, it was laid down for awhile,not won't get cold?
Hello. When a fridge is laid on side the fluids in it flow away from necessary areas. Always stand the fridge upright for at least 48 hours before plugging it in. My recommendation is to unplug it and let it sit for 48 hours and then plug it in again. regards, Joe
Feb 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge isnt cooling and we just moved house, it was cooling before, im not sure whether it is needing to be regassed or if the thermostat is dead. how do i tell and how much do each of them cost to get...
hi did you have it laying down when in transit ...if yes you needed it to be standing upright for at least 8hrs befor turning on .... if you switch it on its more likley you req a new fridge :( they oil from compressor would have gone through your back panel pipes.... if it was stood up then change your stat...hope this helped.
Jan 04, 2010 | Refrigerators
Moved fridg to new house pluged it in dosen,t get coled at all!!!
If you had to lay the fridge down to move it? Then you have to let it stand upright for at least 24 hours before you can plug it in and use it or it won't cool, as oil will get into the coolant lines and foul the works.
If you didn't have to lay it down, then check for a switch and or harness under the front grill that may have got bumped out of adjustment of knocked the plug off.
I hope this helps you, and good luck.
Sep 16, 2009 | Maytag MBB2256GES Bottom Freezer...
Can I transport a whirpool side by side refrigerator / freezer, laying it down on it's side for 5 hours?If when I reach my destination I stand it upright for 48 hrs. before I plug it in.
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
Jul 17, 2009 | Dometic RM2193 Compact Refrigerator With...
Moved The Fridge, Not cooling
Check the evaporator fan inside the freezer compartment.
Dec 23, 2007 | Amana ABB1927DE Bottom Freezer...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
67 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
