Question about Olevia 227-S11 27 in. LCD TV
The screen stays black (no image) while sound is OK
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the sreen, if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter baord to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 16, 2010
  • Olevia Master
  • 8,457 Answers
Ur tv now turn on,have a picture flicker a few sec. than dies,just have sound left?Yes,than the 2 or 1 long boards call the LCD inverter boards are dead.The 1 or 2 long LCD inverter boards,these 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a those 1 or 2 long LCD inverter board for the replacement.
Posted on Jul 15, 2010
I have laptop by fujitsi it runs normally but the screen is completely black
When the display shows the following cases, that need to be replaced a LCD Inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Aug 16, 2013 | Fujitsu Siemens KBPC SX Keyboard
Laptop black out
When the following situations, you need to replace the LCD inverter:
More:http://www.lcdinverter.info/acer-travelmate-8001-lcd-inverter-p-2046.html
Aug 08, 2013 | Acer Computers & Internet
My screen is all black with the words no database what does this mean ?
When the following symptoms, the need for LCD inverter with a: No image on the screen, but the power light stays on
Aug 04, 2013 | Sceptre Computers & Internet
Tv goes on normaly but after about 10 min the image goes off the sound stays ok but with a black screen
open the TV and test the capacitor that supply voltage to the variable resistor the control the brightness.
Jul 03, 2011 | Televison & Video
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Computer turns on but screen stays black
This is often caused by the screen lights or screen failing. Try looking at the screen from different angles in different light conditions, you might just be able to see the image.
Oct 02, 2009 | Dell InspironTM 1501 Notebook
Replaced screen computer comes on, but screen stays black.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 22, 2009 | Dell Latitude D600 Notebook
The screen stays black but have only the sound
if u have sound, hold a flashlight to the screen and look for a picture. if u see a pic, the backlight/inverter has failed.
Dec 06, 2008 | Televison & Video
Camera LCD - black pictures
When I take a picture, there will be know image. Black. I went into the "share" and the image is black. I kept my smart card and the other images are ok but the knew ones are black. Camera has power. I took the smart card off. Still the problem, black. Took the old images off and took some more shots. All black!! MMMMM?
Sep 02, 2008 | Kodak EasyShare DX4330 Digital Camera
Olevia 227-S11 27 in. LCD TV Logo
215 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
