Question about Campbell Hausfeld Air Tools & Compressors
Changing motor back to 110 from 220 would like wiring diagram of motor and correct position for 110v It is a gould century motor 2hp 1phase 220/115 frame y56,model 8-141460-20 code h
Bat1956
  • 585 Answers
SOURCE: change from 220v to 110v on air compressor
I can't blame you for askig, but here's my response. 5 HP is 3750 running watts. or about 35 amps at 110 volts and it would take somewhere around 50 amps to start it provided the motor could even be wired for 110 which I don't believe it can and for that exact reason. I'm sorry, but it's just not practical.
Posted on May 18, 2009
dmftrucker
  • 1922 Answers
SOURCE: Wiring diagram to convert Craftsman 5HP Air compressor
look on the motor cover or on the wiring cvr on mtr or on the inside of the wire termination cvr
Posted on Oct 06, 2009
buffalonyman
  • 1865 Answers
SOURCE: need wiring diagram for a ge triclad motor
Not all motors are dual voltage, the motor must state on th ename plate that it is dual voltage and can operate on 115
Posted on Oct 23, 2009
c7121
  • 160 Answers
SOURCE: how do i change my century 2hp electric motor on
ASSUMING U HAVE 4 WIRES; 2-110V, 1-GROUND, 1-NEUTRAL. REMOVE AND OR DISCONNECT 1 OF THE 110V WIRES. IT STILL MAY NOT WORK PROPERLY BECAUSE U NOW JUST HALVED ALL THE VALUES; AMPS, OHMS, ETC.....CONSULT AN ELECTRICIAN 1ST.
Posted on Dec 13, 2009
  • 553 Answers
SOURCE: I have a gould century 1 hp motor i need it to run
There should be a wiring diagram on the motor name plate. If it isn't there, there isn't much anyone can do, there are literally hundreds of different wiring methods for single phase motors.
Posted on Jun 11, 2010
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Nov 06, 2014 | Goulds Pumps GOULDS GT20...
Rcvd new pentair 1 hp pool pump replumbed and did the electrical connection. motor get real hot and shut off. i used the correct 12 ga wires and wire it for 115v. do you think i got a bad pump. it did...
Assuming everything is electrically correct, the motor probably has a short in the winding somewhere. The motor should have a one year warrantee on it. Any pool store ought to be able to trade it out for you.
Sep 14, 2013 | AO Smith 2hp Pool Pump Motor Ao Smith...
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
Just replaced a Hayward 2hp pool motor with a OA Smith 2hp pool motor and when i turned it on it starts to switch between high and low and it shuts off. the motor makes a tic tic sound. What do you think...
Hello
No there is no switch in the motor.Correct voltage is done by hooking up incoming power to a combination of internal wires or contacts.
There should be a wiring diagram on the cover where the hookup is.Or on the outside case of the motor.
The high and low speed doesnt make sence to me.Check the rpm of the motor it should be one rpm continueous.
Unless this is a Hvac motor and not a pool pump motor.Possible you may have been sold the wrong motor.
Usually a pool pump is 115 volts 1 speed and 1 rpm continuos duty.Unless you specify 230 volts.
Aug 09, 2011 | AO Smith 2 HP 115/230V 56C Replacement...
I want to run this compressor "RITIN RT2012" 2HP 12L (1.5kW) compressor. It's a 110V AC drive unit and I have 240V. Can I run it or do I need to convert the Power supply.
You can't just run it on the 240 Volt supply. Check the motor nameplate. If it says it is rated for 110/220 or 115/230, or 120/240 Volts, then it is capable of running at 240V. This will require a wiring change, and you may need a larger size power cord.
The electrical diagram should be on the motor name plate or under the cover to the electrical terminals on the motor.
May 25, 2011 | Air Tools & Compressors
I have a gould century 1 hp motor i need it to run on 115 and it had previously been tried at 230,i had it running for a sec but it isnt right ......i need to know the proper wiring ....also it has 6 posts...
Jun 11, 2010 | Air Tools & Compressors
How do i change my century 2hp electric motor on my air compressor from 220 volt to 110 volt
Dec 13, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
623 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
