Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Power is on -no pic/sound
Green light on front comes on when i push power, however no pic and no sound
  • Philips Master
  • 3,459 Answers
Problem solved.
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Posted on Jun 20, 2008
    Genius:
  • 1,139 Answers
Hello Immirich,
It sounds like you may have a power supply problem, since the TV is not clicking, I am going to assume that you are having a low voltage power supply issue. First I would power off and unplug the TV. Then I would take an ohmmeter and make sure that all of the fuses were good (set ohmmeter to Rx1 and measure across the fuses (it should read 0 ohms) after checking all of the fuses. Then I would do a brief check of the Horizontal Output Transistor (HOT) or the High Power Metal Oxide Semiconductor Field Effect Transistor  (HP-MOSFET), whichever one is being used making sure that the lead that should be connected to the + power supply (Vcc) is not shorted to ground. If it is shorted, I would do a test of the IHVT (resistance (coils), Capacitance(between Anode and the metallic band of the core), and Ringer (primary side of the IHVT)) and the HV capacitor to make sure they were OK. If they are OK just replace the HOT or the HP-MOSFET and try to power on the set. If the problem was just the HOT or HP-MOSFET it should be working, if not the other tests mentioned will more than likely point you to the problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Apr 29, 2008
3 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: won't power up
Look on your deflection board cp150 green capacitor with gold writing on it will have value of 2200uf 16v if this capacitor is bubbled up on top it is bad so replace all 3) cp150, cp111, cp114.
Posted on Oct 18, 2008
SOURCE: tv will not turn on
the on light bleek but it show no picture
Posted on Jan 15, 2009
No pic no sound, but power on
Apparently power is getting to your TV but the internal power supply has failed
May 18, 2013 | Toshiba 55G300U TV
My tv wont show a pic or sound. the green light comes on and it clicks but nothing. its a sony bravia kdl-55ex710. its happened before and my husband played around with the home button. it occassionly...
On the remote control to that tv, after the power is turned on, find and push the input button untill you have a picture. The input button switches where you are receiving your signal from, cable, component, video 1, vedeo 2,,etc,,,.
Hope this helps
Apr 19, 2011 | Televison & Video
Phillips LCD TV,green power light changes to red blinking light when power button is pushed.no pic and no sound.
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Dec 18, 2009 | Televison & Video
Have green lights but no pic...also unit very hot
those units are known to go out after not long at all try doing a front panel reset by pushing the red button where the access card is you may have to do it several times to see if it will finally come up if not your looking at buying a new receiver
Aug 15, 2009 | Philips DIRECTV H20 DTV Receiver
Rca 52 inch power light comes on no pic.,shuts off makes noise
I think you have a shorted hori output Transistor NTE2324 if it makes a low squealing sound also ck capacitor 114,120,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and other 2 are 220uf 35v.
Apr 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on
Jan 15, 2009 | Televison & Video
Kicker DX350
it sounds like you pop the power Reg. transistor or one of the Amp. chips instide. Some Amps has a pic fuse inside on the main board its green very small shape like a tear drop with a wire comeing out both ends it would in a socket some times white or black.
Sep 22, 2006 | Kicker DX350 Car Audio Amplifier
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
