Question about Amazon Kindle 2
How do i turn read to me on - Amazon Kindle 2
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 7 Answers
Here are the shortcuts:
  1. Shift+Sym – start and to stop TTS (Text To Speech or Read To Me in Kindle 2). You have to keep Shift pressed down and then press Sym.
  2. While TTS (Text To Speech or Read To Me in Kindle 2) is on – Use Shift button to Pause or Resume it. Note: this might be Space (spacebar).
  3. While TTS (Text To Speech or Read To Me in Kindle 2) is on – you can switch between male and female voices, and change voice speed by using Alt + Aa keys and then using the 5 way controller.
  4. To start TTS (Text To Speech or Read To Me in Kindle 2) at a particular place on a page, move the cursor to the spot BEFORE starting TTS.
For the full manual, go here:
http://www.amazon.com/gp/help/customer/display.html?nodeId=200317150
Posted on Jul 15, 2010
Hard to read
Tablest have different screen cofig parameters. Look for it in your Setting menu item.
Apr 24, 2015 | Tablets & eReaders
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
My ipad won't turn on, can it be fixed?
Double click the Home button to see if it's running.
Try charging the battery for at least 8 hrs.
If nothing happens you may have to start over.
Hope this helps.
Mar 06, 2015 | Apple iPad Tablets & eReaders
Kindle turns seof off when I am reading a book.
you need to disable your turn off when idle functions. Its in the preference options.
Feb 13, 2015 | Amazon Kindle Paperwhite
Screen keeps rotating while I am trying to read?
It should not rotate if the position is locked. To lock the screen, pull down the upper menu by either touching the screen on the upper right or (if it's an HDX) sweeping down from the top. On the left is an icon, the lock screen icon. Tap it until it reads "locked". If this does not work there may be a malfunction which requires a repair.
Dec 19, 2014 | Amazon Kindle Fire HD
Can I read a book on my Verizon Nexus 7 without connecting to wifi (and incurring charges?)
You can download ebooks to your tablet for reading offline. But the data rates for downloading the books still apply unless connected to wifi. Free Wifi is available at most fast food stores, libraries, and hotels. You can use these places to connect and download ebooks then read them at home.
It is also a good idea to turn on airplane mode whenever you do not want your device to use data as other applications (System updates, facebook, amazon apps, etc) will also use data even when they are not open on your screen, many will continue to run in the background.
Nov 17, 2014 | Tablets & eReaders
Battery only holds for 3 hours despite following all instructions. that's 3 hours of reading time with wifi turned off
I would replace the battery then, if the battery isn't removable then you could buy a used device on eBay for $30.
Dec 14, 2013 | Nextbook Premium 8 Se Android
When I turn on the computer,I get amessage that read's Invalid partition table. What is this & how do I repair it?
PC repair will fix PC issues and Driver solution will get the right drivers for your PC. I use these tools and costumers almost never contact me saying they have a problem.
Dec 19, 2011 | Samsung Q1 Tablet PC
My kindle is frozen. I cannot reach my home page. I am stuck between the last thing I was reading and the kindle store and I cannot go anywhere else. It has been like this for 3 days.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Dec 15, 2010 | Amazon Kindle Wireless Reading Device
Amazon Kindle 2 Logo
241 people viewed this question
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
