Question about Medion MD-1768 PC Desktop
Restore will not work comp goes thru the motions and comes back with unable to restore, it doesn't matter how far back you go
  • 487 Answers
Hi, I believe you need to reinstall your operating system, follow these instruction:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Posted on Jul 15, 2010
Windows XP freezes half way through Restore program?
Select an earler restore point. If it still doesn't work step back earlier. Somewhere in the restore date history there has to have been a date where the system worked. Remember that the restore process can take some time if a lot of material has to be restored
Oct 26, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
I have what I think is an Inoi Sata multimedia hDD ( Square aluiminum case) .I have connected it to a Windows 7 computer and has failed to be recocognised. Where do I find suitable drivers thanks
you should not need drivers for that all, windows should be able to recognize it.
These things usually need an external power supply, first check if it is connected.
Try it with a different computer. If it works then I suggest a system restore on the other comp.
If it doesn't work (which is likely) then you should take apart the metal case, remove the HDD (which is a totally standard desktop HDD) and plug it inside the comp with the SATA port. Windows then will correct the disk errr upon turning on. If it doesn't work this way either then it's dead. If it works flawlessly, but when put back into the case it doesn't wok again then the housing is faulty.
Aug 11, 2011 | INOi HD370 300 GB USB 2.0 Hard Drive
IPhone has been locked up for 3-4 days, 'Have called at&t tech support multiple times and am unable to reach alive person. the recording is as follows: "Please note, some customers in your area...
Hi..have you tried your SIM in a different phone and does it work?? If not then its most likely the network with the issue not the phone but if the SIM does work in another phone all i can suggest really is to try restore your phone from a back up from before you started having trouble with it...so say you have a back up from 3 days before you had the issue then restore from that...restoring from a back up will prevent you loosing all your iphone data.. if that doesnt work im afraid you'll have to restore your phone as new to wipe it and basically start fresh..
Hope it helps!!
Use the following steps to restore your device: before doing this please make sure you have your comp powered up and an updated version of itunes on it.
  1. Power down your phone and holding down your home button for around 6secs, connect to your comp still holding the button until you receive a message on itunes saying an iphone has been detected in recovery mode, then continue to restore your iPhone.
  2. Select the Restore option.
  3. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  4. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  5. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  6. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new..."
Dec 28, 2010 | Apple iPhone 3G
Helpppppppppp
If you are restoring it through itunes you should not really get this problem. Have you downloaded the latest version of itunes? It may be driver related. Download the latest version of itune here
http://www.apple.com/itunes/download/ it will have all of the necessary drivers for your ipod.
Then try to restore your ipod using itunes.
Hope this helps you resolve your problem
Oct 27, 2008 | Apple iPod MA446LL/A MP3 Player
THE LCD SCREEN IS BLACK AND I CANT TAKE A PICTURE. BUT I CAN STILL VIEW MY PICS. THE CAMERA GOES THRU ALL THE MOTIONS LIKE IT IS TAKING A PICTURE BUT IT IS JUST COMING UP BLACK.
The LCD screen is black and I can't tace picture. But I can still view my pics. The camera goes thru all the motions like it is taking a picture but it is just coming up black.
Aug 31, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
T3302
Click Start (bottom left of your screen), right click My Computer, in the drop down menu select properties. Whe the window opend in the top left tab, select System Restore.
Make sure the little "Turn Off System Restore" box is not checked.
What operating system are you using?
What version of Norton are you using? and is it a paid for version or a trial version?
Jul 23, 2008 | E-Machines eMachines Desktop PC
How to empty fax memory.
The setting for resolution was too high. Set back to basic and fax went through--no more problems.
Feb 08, 2008 | Brother MFC-5440CN All-In-One InkJet...
Loaded film wrong??
I'm assuming you're not able to shoot pics. Its my best guess that the film just isn't getting loaded properly. Next time you attempt to load film there maybe a small red mark near the take spool (bottom edge where film goes) to indicate how far you need to pull the leader forward toward take up spool. I think the film isn't out quite far enough for the camera to do its auto load thing & when you close the back it goes thru its auto loading motions but the film just isn't getting loaded. Then close back & see what happens.
Apr 27, 2007 | Konica Minolta Maxxum QTsi with 35-80 lens...
My printer go thru the motions of printing a doc but comes out blank,( it will print internet stuff)
tried to check printing connecting at another computer (not networking)? icq 475653626
Sep 26, 2006 | Canon BJC S300 InkJet Printer
Medion MD-1768 PC Desktop Logo
90 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
