Question about Hayward Pool Products Hayward Xstream Filter 150 Sq Ft, 1.5 HP Pump/Timer
We have a hayward xstream pool pump for our 18' above ground pool that my daughter got through make a wish last august. we cleaned the cartridge yesterday and when we replaced the cartridge it started making a terrible noise. we have taken it apart several times and we cannot get rid of the noise. do you know what it may be or anything we can try? thanks-shannon
  • 640 Answers
Try taking the pool filters cartridge out and following these steps to make sure that it is installed properly.
1. Clean debris from bottom of filter tank.
2. Replace element evenly on the collector hub in bottom of the filter body.
3. Place lid evenly on filter body and turn Easy-Lok™ ring clockwise until the safety latches engage securely.
4. Close and secure drain plug (located at the base of filter body).
5. Open air relief valve (Turn lever to left).
6. Open valves (Optional suction & return valves).
7. Prime and start the pump.
8. Once air has escaped the filter and a steady stream of water is flowing from the air relief valve, close the air relief valve and note the pressure gauge reading.
Posted on May 24, 2011
How to take off locking ring from top lid to replace on Hayward xstream filter sysyem,I need to take the locking ring complently off so I can replace locking ring
Hi Mark, The link below is a user manual for a hayward xstream filtration series, This is from that manual...
Depress safety latches (located on the underside of the locking ring handles) and unscrew locking ring in a counter-clockwise direction. Remove lid from filter body.
Hope this helps....CHEERS..
https://www.hayward-pool.com.au/pdf/manuals/XStream-CC2000.pdf
Mar 27, 2016 | Pool & Spa
How do I unlock my Hayward Xstream filter. I can not get the filter top off
Same problem, brand new filter... I'm 190 lb guy who works out 6 days a week, I can't open this filter for the life of me. If I knew it would be so hard to open I'd have opted for a less expensive sand filter. Cartridge are supposed to keep the water clearer but if you can't open the filter to clean it without spraining a wrist or having a heart attack (or both) what good is it? Beyond mad, I'm thinking of just biting the bullet next spring and buying a filter that actually opens. Even the brand new Hayward chlorinator didn't work properly this past summer, i,thought they were supposed to be good products, dealing with their customer service is pointless.
Sep 13, 2014 | Hayward Pool Products Hayward Xstream...
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
Hayward xstream pump vibrates and makes noise and we have done everything in the manual to correct the problem i'm tired of taking it apart to put it back together to get the same results NOISE I...
i had the same problem tryed every thing then i called hayward they told me the housing in the top of the filter was worped they sent me out a new filter to and locking ring and cartridge for free awsom call customer service 1-908-355-7995
Jun 22, 2011 | Hayward Pool Products Hayward Xstream...
Brought a used hayward pool. no instructions on how to set up the pool. help
Here is a copy of the users manual for these pool filters. It has detailed pictures that should help you get the filter up and running in no time!
http://www.backyardcitypools.com/images/hayward/swim-clear-manual.pdf
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
I can't get the lock ring off to get the cartridge out to clean! It spins about half a turn then stops, HELP!
There should be two buttons (for lack of a better word) on the underside of the ring you push up on to unlock as you turn. Once it is off turn the pump on for a second or two to pop the lid off. When putting back together close air bleed and fill bottom of filter with water then put the top on and as the water tries to drain back to the pool the suction will help pull the top down into place.
Jun 25, 2010 | Hayward Pool Products Hayward Xstream...
Sand in backwash
You need to replace the seal in the head unit of the filter.. The sand should be replaced every three years or buy a cleaning solution.
Jun 17, 2009 | Hayward Pro Series 18" Above Ground Pool...
I had a pond installed with a Hayward Xstream pump and filter. I cannot get the manuel from the contractor. It has been about 6 months. I need to know how to service it. The model numbers are CC 100925 and...
Manual for the filter:
http://www.haywardnet.com/products/Manuals/pdfs/Manual126.pdf
Manual for the pump:
http://www.haywardnet.com/products/Manuals/pdfs/Manual131.pdf
Your model numbers don't match _any_ Hayward products.
The above manuals aren't an exact match to your model numbers, but should be in the ball park as far as maintenance and service along the Xstream product line.
Jan 11, 2009 | Hayward Pool Products Hayward Xstream...
Hayward Pool Products Hayward Xstream Filter 150 Sq Ft, 1.5 HP Pump/Timer Logo
394 people viewed this question
Top Hayward Pool Products Garden Experts
roeb
john h
Marvin
Marvin
Are you a Hayward Pool Products Garden Expert? Answer questions, earn points and help others
