Question about Samsung LN52B550 52 in. LCD TV
My TV is blacking in and out, how do I fix this? I went on vacation for a few days and came back to this problem. I attempted to unplug it overnight but when I tried it today it did the same thing. The TV is less than a year old.
  • 712 Answers
If the t.v is less than an year old, it might be well inside the warranty period. So the best thing you can do is to report them or take the t.v bake and ask the company's mechanics to fix it for free.
This one is a common problem for L.C.D screens. 6 screws that attach the inverter board to the LCD gray metal bottom loosen over time, causing the TV to periodically lose video while retaining audio. Sometimes turning the TV off and on again restores video, sometimes not. The problem gradually gets worse making the TV unusable.
To fix it yourself is a time consuming and difficult task, although you need no additional devices to be replaced. The disassembly and assembly may eat a lot of your time. But if you are still interested get yourself a service manual (must have came with the t.v or you may download it) and follow the disassembly instructions given in it. Go through the following steps: Stand Disassembly, Back Cabinet Disassembly, Angle Back Disassembly and LCD Cover Disassembly.
Once the LCD cover is removed, on the left side you can see the metal cover of the inverter board and the six screws holding it down, the very screws that we have been looking for! Remove the six screws and the metal cover. Without disconnecting any of its connections, rotate the inverter board up and to the left to expose the bottom of the inverter board as well as the gray metal bottom of the LCD to which the inverter board is attached and grounded. Note the 3 copper rectangles on the bottom of the inverter board surrounding the 3 screw holes away from the left edge towards the middle of the TV. These are the grounding strips that lose their connection.
Using contact cleaner clean off any black burn marks from these connectors. Also clean all black marks from the grey metal bottom that they contact. Clean carefully and thoroughly. You might need to scrape lightly to remove all marks.
Rotate the inverter board back in place. Line up the metal inverter board cover. You can either use the 6 existing screws or purchase replacement screws (only if you are not satisfied with the old ones). Using a removable thread locker coat the screw threads of one screw. Tightly screw in the middle edge screw first. Follow this by the edge top and bottom screws, then the middle inner screw, and finally the top and bottom inner screws, using the threadlocker on all 6 screws. Verify that all screws are tight.
Now start the reassembly in the reverse order of your disassembly. If you have done everything fine, you can find your t.v working fine.
Best Regards. Thank You.
Posted on Jul 15, 2010
Front load washer stuck on final spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Sony FD Trinitron WEGA
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My 32HLX95 won't turn on. Went on vacation, TV
Unplug,replug an hour later see what happen.Power Supply board might need to replaced.
Feb 24, 2010 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
Lg 42'' plasma 720p no picture
This is not good. Was your tv unplugged or just power button off when you left for vacation. PlasmaTvs are highly susceptible to damage from power surges caused by lighting. Leave unplugged for at least five minutes then plug back in and see if this helps.
Aug 15, 2009 | LG 42PQ30 42 in. Plasma TV
My Philips GoGear MP3 Player is stuck
Been using this for a few months. Froze up on same song while on vacation last month, and continued to play same song on repeat until battery went down. Now is frozen with "Do Not Disconnect" as it was being charged on my laptop. Attempted to unplug and plug back in and Windows gives DO NOT DISCONNECT!!!!!
I am having the exact same problem!!!!!
Aug 02, 2009 | Philips GOGEAR SA6045 MP3 Player
Black box on screen
Try unplugging your tv for a few hour/days to let it reset itself to default. Hope that helps.
Dec 28, 2008 | JVC AV-27530 27" TV
Philips 27PT6441/37
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
May 03, 2008 | Philips 27PT6441 27" TV
LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Open Questions:
Samsung LN52B550 52 in. LCD TV Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
