Question about Saniflo Sanibest macerator with multiple connections
I have been called out to look at a Sanibest system which stays on all the time. My guess is probably float switch related. Are there any service/maintenace instructions other than the user instructions available from the Saniflo website? Alternatively could it be anything else other than the float switch?
    Problem Solver:
  • 8 Answers
I had the same issue before. Definitely has to do with the float switch. Could be that a piece of solid is stuck at the bottom of the float switch or the membrane (black rubber piece at bottom of flat switch) may be warped/deteriorated and will need to be replaced.
Posted on Jul 20, 2010
Saniflo is working its only connected to a sink but only pumps three quaters of the water away then stops and leaves rest of water in the sink
Sounds like the pump needs to be de-watered completely and cleaned. There is a pressure chamber that contains, I am guessing here since I hve never taken one apart, a float and a microswitch. If the float gets heavy with gunk or gets a hole in it, it will not float as well and will take more water in the drain pipe to cause it to rise up and activate the micro switch. I don't know how hard it is to disassemble these units but hope it is fairly simple since they are pricey. You said it was only on a sink, not a toilet or both. It is possible that grease has built up (the gunk) and a hot water flush may do the job for you but it will take a lot of hot water flowing through the grinder, that of some grease dissolving drain cleaner.
Oct 02, 2012 | Saniflo Sanibest Grinder Pump Only 013
Every time the float operates the switch to on the fuse trips out?
It sounds like the impeller for the grinder pump has something fowling it and you will need to pull the pump or at least clean it out.
Mar 04, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
The unit is several years old - the float keeps falling in and the unit shows full -can I get a new float and will that fix the problem?
If the float falling in tells you its full probably not. Unless the float floats off a switch. Then a new float that wont fall off would probably do it.
If the float keeps falling off...why not tie a small piece of fishing line to it and suspend it above the switch? It will stay where its needed until water lifts it up.
Jun 27, 2010 | Maytag M7DH45B2A Dehumidifier
The saniflo system used to leap into action at the first drop of water now it is not doing this.Also. the system is making a very loud noise and keeps working away and not switching itself off.I should add...
Sounds like the pump is clogged and needs to be cleaned , or the float switch is clogged or stuck . The pumps that come with these units are under ratted and should be upgraded to a better pump. But just cleaning it out and checking the float is what needs to be done.
Apr 27, 2010 | Saniflo Sanibest macerator with multiple...
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
LOW COOLANT LIGHT STAYS ON ALL THE TIME EVEN WHEN SYSTEM IS FULL.
The float is most likely stuck or the switch is bad. The switch and float are usually in the plastic surge tank. Usually that tank comes off fairly easy, you could try taking it off and shake it that might jar the float lose.
But, if it sticking I guess I wouldn't rely on it, check the coolant level periodically.
Dec 23, 2009 | 2003 Pontiac Grand Am
The toilet was installed under the stairs a year ago and has hardly been used - the bowl keeps filling after flushing and overflows, I cant shut it off. It flooded the down stairs twice now - all over...
Take the lid off the cistern tank and have a look. There is a ( usually ) round float ball in there. This is what is causing it. When the cistern fills up the ball is supposed to float up and the arm it attaches to shuts off the water, usually at the opposite end to the float.
Turn the tap on the pipe to the cistern so it is nearly off and move the arm up and down by hand. See what it is getting stuck on or what is happening.
If it is not a simple sticking problem, you may need to undo the top of the cistern valve itself ( opposite end to the ball. )
Turn the water off completely to the cistern to do this or you will get squirted. :)
They are fiddly little valves and all a bit different but if you take your time and make sure you have a good light you will be able to work out what has been happening.
Hope this is some help.
Oct 17, 2009 | Saniflo SaniBest-Round SaniBest Macerator...
Emergency brake light stays on, weather brake is pulled or not. toyota 1990 pickup 4x4. any guesses?
did you check the float inside the master cylinder reservoir or check the limit switch for the e-brake lever to make sure it is making full contact?
Jul 15, 2009 | 1997 Toyota Tacoma
Incoming call rings one time and disconnects
Unplug all phones but one in jack 11 at the cabinet and have someone call in. If it doesn't work, you probably have a bad cabinet. If not, I'm guessing one of your extensions is faulty.
Carl
Apr 06, 2009 | Panasonic KX-TA308 Phone
Empty water light staying on machine will not work
Probably sticking float switch
Remove lower bottom left filter completely run water thro it to clean all fluff out reach inside and clear any build up of fluff that you can see or feel.
At the back of this aperture is a small hole that gets clogged up,feel for it and poke a plastic bag tie or similar, and poke it clear, if this does not work then it would probably involve a strip down to access the float chamber and switch assy.
Plz rate my solution.
Thanks.
Dec 13, 2008 | Hotpoint TDC32 Electric Dryer
Saniflo Sanibest macerator with multiple connections Logo
303 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
