Question about Weather King 10AJA4201AH Air Conditioner
Stops at nigthnever stops runing in the day time has a newthmosite setting is on 76
  • 57 Answers
Might be low on freon charge. can't cool enough during the heat in the daytime so it runs continuosly. a service tech with guages can tell.
Posted on Jul 16, 2010
Honeywell thermostat "In Recovery" Message?
In recovery only shows on programmable stats. It refers to the adaptive recovery when using the programming. Over time the stat will learn how long it takes to cool or heat to the programmed set point. For example, if during the day the programming is set to 80?, and at 4:30 the programming drops to 76?, if it takes 2 hours for the temperature to reach 76?, it will learn that it takes 2 hours and eventually it will start turning on at 2:30 so that at 4:30 the temperature is satisfied instead of at 6:30, at which point it is no longer in recovery
Aug 05, 2014 | Honeywell Heating & Cooling
User manual for jnc JAC-24Y2???- want to know what the optimal setting for heating temp is for economy in the unit. We seem to have to have ours set quite high to get the unit to run consistently. If we...
Normal settings 70 heating 74 to 76 cooling, I try to leave my cooling a 76 and keep it there. 76 degrees feels good if its 95 or hotter out side and the lower you set it the more it will cost.
Jul 03, 2011 | Heating & Cooling
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
Dg31 pr motherboard problem
Does it show the correct CPU speed under My computer? Did you go through the BIOS setup screen and set everything up? Are you ram chips a matched set?
Jan 18, 2009 | Intel DG31PR Motherboard
Runs hot at 70
sounds like the radiator is blocked replace it or have it cleaned at a radiator shop
Dec 29, 2008 | 2003 Land Rover Freelander
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Psp freezes up during certain games
bet you are playing on a slim, turn of the umd cache in system settings then the problem stops perhaps the game (driver 76) doesnt support the umd cache system using the extra ram in the psp slim
well it worked for me anyway
Jan 26, 2008 | Sony PlayStation Portable (PSP) Console
Blower won't stop runing.
First I would make sure that at the thermostat your fan is not in the on position rather than auto. Your other options are that your blower relay may be "stuck" or possibly the installer wired it improperly making it hot all the time.
Oct 25, 2007 | Heating & Cooling
Weather King 10AJA4201AH Air Conditioner Logo
32 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
