Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Quiet Wash 1 Ultimate washer doesn't drain the water
Hello I have a Whirlpool Quiet Wash 1 Ultimate Care II. It goes thru the washing cycle, and then it doesn't drain the water, I hear humming noice. There is no blocks in the drain pump, removed and reattached the agitator. Still same humming noice (something like cluk cluk...... in very low noice). Top part of the agitator turns in one direction only, lower part doesn't turn when I try to turn.
Thanks
RK1234US
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
  • 1073 Answers
SOURCE: WUC II
check the lid switch, if it is ok go to the pump and see if anythig is in it, if nothing there motor issue
Posted on Apr 13, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash fills and does not drain
Check your lid switch. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
If you have questions, please let me know. I hope this helps you.
Posted on Jul 20, 2009
SOURCE: Filled with water, will not drain or agitate,
Agitator dogs, I go through a set every 2 months. It has gotten so I can replace them in 3 minutes.
Posted on Sep 28, 2009
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
A Whirlpool Ultimate 11 Quite Wash II with a switch issue
Use the steps in this video to access the parts.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin, won't drain
Hi...
If your washer does not drain, you need to check this:
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
If it does not spin check also this:
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't drain water for rinse
your lid switch is defective..replace onthejob
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer not going thru cycle
IF YOUR MACINE WONT PUT WATER IN IT WHEN YOU TURN IT ON ITS THE WATER INLET VALVE IN BACK WHERE YOU HOOK UP THE WATER. IF THE WATER GOES IN WHEN YOU TURN IT ON THEN ITS MORE LIKELY TO BE YOUR LID SWITCH. YOU CAN GET EITHER OF THE PARTS AT YOUR LOCAL APPLIANCE DEALER OR EASILY ON LINE. JUST HAVE YOUR MODEL NUMBER HANDY. GLAD TO BE OF SERVICE.
Nov 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
705 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
