Question about Sony XPLOD CDX-GT200 CD Player
I have a sony explod head unit installed in a 1987 volvo sedan DL and I left the cd in it over night so Im almost certain its either warped or damaged because the cd player will not spit out the cd at all....my question is, how can I get it out?..and would I have to get a new headunit ultimately?
    Master:
    Sergeant:
  • 383 Answers
Try operating on the patient
remove and open it and see what you are able to remove safely
if you get it out try it again and then if works lesson leaned dont leave cds in it, if you does it again youll need a new cd player
Posted on Jul 16, 2010
Sony car stereo, cd working but not radio
I'm an MESA certified installation tech for car audio, Pull your head unit out and make sure that your antenna cable is properly connected! If that's not it let me know!
Aug 26, 2012 | Car Audio & Video
1987 Dodge Ram 50 wont start and no compression after it over heated
Bad news more than likely you warped the head and blew the head gasket. remove the head (the one with no compression) take to a large parts store or machine shop and have them check it for warp. If it a warped steel head they can plane it down. If its a warped almum. head you might want to get a new or good used one. save yourself some over heading problems down the road.
Oct 07, 2011 | 1987 Dodge Ram 50
Id the 1986 DL a wagon only or can be a sedan, trying t find used part - Driver side tailalight
The sedan and the wagon have completely different tail lights. I suggest Volvo Saab Recyclers in Rancho Cordova, CA. They ship anywhere.
Sep 19, 2011 | 1986 Volvo DL
1987 Volvo 240 DL water pump replacement?
Oh my, it has been decades since I did one of those, but what I remember is that it is a simple bolt-up installation. I had no problems with the couple that I did.
As with any water pump installation, clean up the metal mating surfaces carefully so they are smooth and shiny before installing the new pump.
There are two spots that are prone to leak after you finish. One is the O-ring where the water pipe presses in to the hole in the back of the water pump. Make sure the surfaces are clean and smooth and the O-ring is in place and straight. The other place is the seal between the top of the water pump and the head. This one is tricky because there is no bolt that holds the seal joint tightly together. You put the water pump in place and put the bolts in just snug, then you pry up on the water pump, using the fact that the bolt holes are slightly oversized to move the pump up to press tightly against the head. While prying the pump upward, tighten the bolts that secure the pump to the engine block.
Good luck.
Jun 01, 2011 | 1987 Volvo 240
Where can i download a wiring manual for instaling a amp and sub to my head unit its a sony explod cdx-CA750X
All you need to do is run the 2 rca's from the back of the headunit to the amp and run whe remote wire (which is usually blue or marked with a tag) to the amp.
Jul 13, 2010 | Sony CDX-CA750X CD Player
Stereo help
Make sure the red wire on the unit is hooked up to power. The blue antenna wire is hooked up (or to the factory amplifier) and the yellow wire on the radio is hooked up to a key on power supply. If it works and you lose the memory when you shut the key off, switch the red and yellow wire power supplies.
Feb 25, 2010 | 1987 Volvo 240
I have a 1986 240 dl volvo, when i start the car the temp gauge goes right to overheat, after sitting all night, within 3 seconds? what could cause this
your coolant temp sensor wiring is touching ground. im assuming you have a few oil oil leaks. oil and heat on wiring insulation dont mix. find this wire and make sure it is not touching any brackets or the engine block. this doesnt sound like a hard issue. i think youll find something pretty easy.
Nov 03, 2009 | 1987 Volvo 240
Volvo 1989,2.4 litter DL 240 SEDAN
Bring #1 cylinder to top dead center. as high as it will go. Set distributor in line with #1 plug wire. Then begin using timing light to get it set on.
Jun 23, 2009 | 1989 Volvo 240
1987 Volvol DL SpeedOdemeter Sensors
its just a magnetic sensor it doesnt have voltages that you can read as such .
Jan 31, 2009 | 1987 Volvo 240
1985 Volvo 240 - just bought it - eratic idling - was bone dry
The coolant leak could be a blown head gasket. And the not going over 30 MPH could be from the catalytic converter being clogged. Do a compression test for the head gasket, and remove the O2 sensor from the exhaust and drive with the exhaust leaking out the hole. If the lower back pressure allows the car to go over 30 MPH then you know the cat. is clogged.
Oct 25, 2008 | 1985 Volvo DL
Sony XPLOD CDX-GT200 CD Player Logo
62 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
