I got ebac humidex plus dehumdifier i am having problem when i switch on it is having a foul smell and it shake the whole unit and it is not working properly.
2 Suggested Answers
SOURCE: Window AC - foul smell
if the unit is cleaned and this smell is only when the condenser is on means the fresh air is open and this smell comes from outside . because the condenser fan is sucking air from condenser through it to motor side .
Posted on May 02, 2009
Ebac 6200 got no power
Plug a lamp in the socket and see if it works. If it does try the unit, if it does not do anything look for a reset. If you cannot find that (there may not be one) get the schematic and trouble shoot the unit.
Feb 23, 2014 | Ebac Dehumidifiers
I have an ebac homedry 870. works great ,has done for 10 plus years probably 15. Now it rattles, has got quite loud. You can get part of the same noise if you shake the unit side to side. i think...
I see by my computer this is a UK unit made for UK climates.
I also found various web sites you can access for help with your unit. Please explore these.
God bless your efforts.
Jan 02, 2018 | Ebac HD880 Dehumidifier
I have a ebac bd80 and the coils stay frosted ,
Frost means one of two things, low refrigerant or low airflow across the coil. The unit probably has lost it's refrigerant charge ( or some of it's charge) even though it hasn't been used.
Oct 25, 2009 | Ebac Dehumidifiers
My unit has started to trip the circuit breaker
the fan bearing is siezed / check if fan turing freeley
Jun 15, 2009 | Ebac BD150 Dehumidifier
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
2002 LS shaking, engine light on smell fuels
Brother I have the same car. Go trade it in ASAP! The reason your car is doing this, is because there is oil leaking in the spark plug holes from the valve gasket covers. You will not see any oil on the ground and if you ask a regular tech they will say they do not see a problem either. After spending thousands and reading other forums I narrowed down the problem. When the oil works its way down into the sparkplug holes it causes your car to misfire, idle rough, and sometimes die out. There is no way for the oil to escape so it ends up fouling out the plug and ruining the ignition coil which are $85 a piece and there is 8 of them on the V8 engine and 6 on the V6. Also known problems are noisy clunking in the front end. Ball joints go bad and can only be replaced by purchasing the whole control arm. Take the car to a Lincoln dealer and let them tell you what I just told you. Then get the hell out of there because they will screw you with no vaseline. Take it to someone you trust. Happy New Year! 2009
Dec 27, 2008 | 2004 Lincoln LS
Goldstar Dehumdifier - draining through hose not working
Check the connection where you attached the hose. It may be plugged or covered by a plastic film from when it was molded.
Jun 09, 2008 | Goldstar DH304 Dehumidifier
Heating & Cooling Logo
137 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
