Question about Mtd LAWN MOWER PART # 17871D FENDER-REAR HYDRO
My White lt 1650 lawn tractor mower deck belt comes off the pulleys.
  • 12 Answers
SOURCE: Lawn tractor jerks when driving across lawn
Can you adjust tensioner
Posted on Jul 20, 2009
  • 496 Answers
SOURCE: How do you replace a belt to a riding lawn mower?
You will need to get some information from your mower. Click on this link to get started:
http://www.outdoordistributors.com/MTD/MTDpartslists.html
Posted on Aug 25, 2009
bbreton
  • 437 Answers
SOURCE: I have a MTD Lawn Tractor and it has the 18HP
May be time for a tune up; Change spark plug; Air filter; oil, fuel filter. It may be starving for air or fuel.
Posted on Oct 06, 2009
huffman49
  • 235 Answers
SOURCE: I have a model 13AH762F752 MTD Lawn Tractor on the
if the mower deck is on the ground under the tractor raise the front of the deck up and push the deck towards the front u ntil the tabs are lined up with the hooks on the deck..good luck
Posted on Apr 06, 2010
deanbrock2
  • 3 Answers
SOURCE: MTD Lawn Tractor problem
I got the same mower, and I had the same problem when I replaced the rear drive belt today. It's probably a good idea to replace both drive belts at the same time, because of the variable diameter pulleys, if one belt is worn thinner than the other, this could change the intended ratios.
However, I have noticed after running the mower around the yard for 30 minutes, the higher gears are working better. The variable speed pulley is a clever design, it can't hurt to oil the bearings, but you probably don't want to WD40 the actual belts.
Posted on Jun 04, 2010
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How to install drive belt for craftsmen lt 1000
Remove deck belt from engine pulley, then remove the idler pulley for the drive belt, remove drive belt and reinstall.
Jul 11, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Drive belt routing
Parts and Diagrams for Husqvarna LT 18542 954571748 2003 11
OH BOY, lots of information. one belt runs the DRIVE LINE. one belt will run the CUTTING DECK. check out the link.Hope this helps :)
Apr 12, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where do the springs connect to? On the deck of my Craftsman Lt 2000 riding mower.
main one u need is the one on the engage pulley, it connects to pull plate and the center of the mower deck in the hole in deck. the one foe breaks go to brake bar and belt guid bolt in most cases
Sep 24, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to install clutch in craftsman lt 1000
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to replace drive belt.Never replaced. 42' Craftsman riding lawn mower. How difficult is this. How do you access rear drive pully
Take a look at how the belt is installed. Then you will have to remove the mower deck and belt from the pulley on the engine. There is probably something by the engine pulley that you will have to remove so the belt will come off. It might be a shoulder bold or a rod with a bolt holding it on. Same with the rear pulley. Then you just have to put the belt on one pulley and watch your fingers so you don't pinch them and turn the other pulley and the belt should go on. reinstall any bolts you removed and install the deck.
Oct 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT 1000 deck belt diagram
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
Jul 11, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Jun 14, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mtd LAWN MOWER PART # 17871D FENDER-REAR HYDRO Logo
1,390 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Morne Olivier
Are you a Mtd Garden Expert? Answer questions, earn points and help others
