Question about Samsung HL-R4264W 42" DLP HDTV
NEEDS NEW DLP CHIP, whats the cost and will it have to be done for me or can I do it fairly easily
  • Mike LaPres
    Mike LaPres Jul 15, 2010
    How did the conclusion of a new chip come about?
  • mklvctr Jul 15, 2010
    trying to find that out now
  • Samsung Master
  • 610 Answers
A new chip will cost between $250.00 and $300.00. I would strongly recommend having a technician do the repair because the chip is burried behind other components that have to be removed to access the chip. This job should not take more than an hour to complete. You can call 1-800-samsung to find the nearest service center.
Posted on Jul 15, 2010
Wd-65734 dlp chip can't find part for can we change it or better off to buy a new tv?
The part# for this DLP chip is: 276P595010 ( DMD-CHIP:IC-1910-6143W)
http://www.shopjimmy.com/mitsubishi-276p595010-dlp-chip-dmd-ic-new-original.htm
$189.99 + shipping you can shop around for better pricing
I DO NOT recommend this to be replaced by a DIY. I highly recommend an experienced technician replace this as you could make matters even worse if you don't know what you are doing.
so consider your labor costs involved & you may want to invest that money in a NEW LED or LCD TV.
Jul 22, 2014 | Mitsubishi Televison & Video
What does light engine cost and how do I replace it?
If you have the white dots issue, you can replace just the DLP chip. I did it, took about 45 minutes after watching a youtube video. Here's the one I bought. Been about a year and no new problems. http://www.shopjimmy.com/mitsubishi-276p595010-dlp-chip-dmd-ic-new-original.htm $189.
Sep 10, 2013 | Toshiba 65HM167 65" Projection Television
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Jun 04, 2012 | Mitsubishi Televison & Video
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
I have had this samsung dlp for about 3 and half yrs and i have white dots that have saturated the screen , it started with a few here and there but now its just about in there thousands , if you stand...
The DLP chip needs to be replaced.Samsung will cover the cost of the part and labor if you call 1-800-samsung. This is a very common problem that samsung will fix for you, if you call them.
Jun 17, 2010 | Samsung SP50L3HX 50" DLP TV
Dlp tv
There is a chip on the DMD board that needs to be replaced.Samsung is covering the cost of the part and labor for this problem.Just call 1-800-samsung and they will set up the repair with the closest service center. VERY common problem.
May 14, 2010 | Samsung DLP HL-P5663W 56" TV
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
What is causing white spots on my 56inch DLP Samsung Television. It started with on spot 2 days ago and now there is 15
the dlp chip needs to be replaced. samsung will cover the cost of the part and labor. call 1-800-samsung to set up service.
Dec 28, 2009 | Samsung DLP HL-P5663W 56" TV
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-R4264W 42" DLP HDTV Logo
149 people viewed this question
Jerry Greenberg
Jerry Greenberg
