Question about Amana Heating & Cooling
I am currently using a white rodgers 1F79 thermostat and would like to substitute a braeburn 3200 thermostat. The heat pump system is a amana Model GSH130241AA. The reason I would like to do this is that the Braeburn is programable. Thanks Bob
  •  Christopher a Martin
    Hello HOOK I need complete description of all the old terminals & letters & all the new terminals & letters.
The HVAC Guy
  • 30 Answers
SOURCE: Goodman GSH130301AB heat pump with
the reversing valve wire needs to be on the o terminal.nothing will be on the b terminal on the thermostat
Posted on Oct 30, 2008
  • 10 Answers
SOURCE: ruud heat pump
If I understand what you are saying, when your stat calls for cool the unit blows heat and when in heat mode it blows cool. Is this correct?
The problem is on a Ruud unit it does not use an "O" terminal it uses a "B" terminal (Reversing valve energized for heat) where all others use the "O" energized for cool mode.
As for the contactor not closing you need to determin if there is 24 volts between "Y" and "C" at the unit, if not then there is an issue somewhere up the line interupting the voltage, if there is then the fault lies at the unit, defrost boaard or pressure switch. call me and we can diagnose over the phone, this is what I do.
Richard (Rick) Drennan
Global HVAC Distributors
RUUD Field Support Representative / Instructor
rdrennan@globalhvac.com
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Cell (209)456-0513
Posted on Jan 05, 2009
  • 472 Answers
SOURCE: I have a new Rheem
if this is indeed a heat pump you rthermostat should also have a emergency heat setting does it work on that setting... a heat pump on heat wuns the outside unit and has a recersing valve that changes the refigerant flow ..is the outside runnignduring heat mode... if you turn the thermostat in emergency heat the outside should shut down and indoor heat should come on...of this is not happening you have a wiring issue if both are not working... braeburn thermostats usually have behind the cover dip switches... i am not exactly sure what model this is but if indeed a heat pump the thermostat should have a r,w2,y,e,g,c,o,and b terminal... rheem wiring should be as follows
red to r white to w2 , g=green , yellow to y terminal there should be a wire hooked to the b terminal usually brown sometimes orange on the b terminal that is your reversing valve terminal.
you are going to have to make sure the thermostat is configured to energize the b termianl and will have to go into the installer setup to do this...hopefully you still have the paper work on thermostat... most heat pumps use the o terminal for reversing valve but rheem uses the b terminal
hope this helps out some repost with anymore probs...also make sure the switches are set to electric or gas whatever you have heat pump or not etc. inside thermostat
Posted on Jan 05, 2011
SOURCE: On my white rodgers thermostat 1F80-361 air and heat wont work
Mine is doing the same thing!! My daughter and I are FREEZING!!!
Posted on Jan 10, 2011
heatman101
  • 43501 Answers
SOURCE: why is my braeburn 1000 not blowing cold air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 15, 2011
Has anyone heard that t-stat on 4045 is supposed to installed reverse of norm?
User Manual - Braeburn Systems
www.braeburnonline.com/sites/braeburn/files/.../1010_manual.pdf
cooling system control board to test the thermostat installation. This could ...configures the thermostat for normal (NORM NON-HP) heating and cooling systems.
Heat Pump Thermostat - HeatPump-Reviews.com
www.heatpump-reviews.com/heat-pump-thermostat.html
Search Results
    [PDF]User Manual - Braeburn Systems
    This thermostat should only be used as described in this manual. ... configures thethermostat for normal (NORM NON-HP) heating and cooling systems.
Jan 17, 2016 | Toys
Need help understanding how to wire a new programmeable thermostat. I currently have a White Rodgers 1F73 model (non-programmeable) connected. I am confused with the instructions on how to connect the...
the black wire is your common wire, you need to program your thermostat, in the advance mode, to tell the t-stat if your heat pump reversing valve is energized on cooling or heating, is the orange wire connected to your t-stat.= w2/o/b
Dec 20, 2014 | Honeywell Heating & Cooling
How do I fix my my white rodgers f178 thermostat, no heat
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department.
- Check the wires on the terminals make sure that they are not loose
- Reset the unit by press time, up and down buttons make sure the systems is in on position.
- Set the system to heat then and raise the setpoint above room temperature. There may be up to five minute delay before the thermostat clicks in heating If the thermostat click this means its not a thermostat you have a problem with your heating equipment call your installer. If the thermostat did not click the unit should be replaced.
Let me know if you need anything else.
Jan 11, 2013 | White Rodgers White-Rodgers 1F85RF-275...
I have the 1F79 thermostat, how do I change the reading to Celcius?
Display screen has "Malf" in top right hand corner of screen. what does this mean?
Nov 23, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
seconds the thermostat should make a soft click
sound. This sound usually indicates the thermostat
is operating properly. If the thermostat does not
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
No Heat with new White Rodgers 1f85rf-275 Thermostat
My name is Tim Burke from White-Rodgers. If you hear the "click" the thermostat is calling. It would appear that their is a wiring issue to the funace. Please contact our customer service toll free hot line and they will be happy to walk you thru it and assist you. 877-978-7828
Regards,
Tim
tim.burke@emerson.com
Tim
Oct 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
White-Rodgers 1F58-58 to Hunter 44660
This is the corrcet wiring:
G - G fan relay
R - RC1, RC put a jumper RH ( to supply power to the cool and heat)
L - no wire connected (malfunction indicator) tape- off that wire
E - Emergency heat relay
B - W/B ( reversing valve in your heat pump energized during heat )
W2 - Auxilliary heat
Y - Y1 ( compressor contact)
O- Y/O ( reversing valve is energized during cool)
make sure that the system selector is on heat pump position.
Apr 30, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
82 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
