Imy documents wont scan on my computer - Office Equipment & Supplies
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
My Kodak ESP 7 wont scan to my computer
See if you can find an update online for your equipment
Nov 09, 2017 | Kodak ESP 3 Multifunction Printer/ Copier/...
When i email scanned docs from my HP officejet 8500 Plus printer to my email, the pdf's are too large. how do i set them to be emailed at a smaller size.
No problem, you can solve this problem very easily :
Whenever you scan a document directly to your e-mail in a PDF format then printer scans it using its own property and only scans the document without any editing in the font or characters.
But the output i.e. the scanned document in pdf shows the same text using its own properties. That font is selected by pdf and not by the hp software.You can open the scanned pdf file and manually change the font size.
Or else
The best way that I will suggest you :
- First scan the documetn in a pdf file or any format on your computer instead of directly on e-mail.
Because when you scan it to your computer printer will scan the document directly to computer and in this way after scanning you can open and see the document. You can make sure if it is scanned properly or not, however when you scan it to e-mail there are chances when we dont verify if the document is scanned properly or not. If there is any hardware issue or any other error then it will scan half page or a blank page....we wont be able to verify it.
- Also if it is an official document which is half scanned or has some problem in it will give a bad impact on the receiver which is not good for professionals.
- By scanning on computer you can verify the document, can make required changes and will be able to send the document in a proper way. It is going to take few seconds but results will be fruitful....try it..!!! I do the same way and there is not much difference
Feb 26, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How do i scan a document?
Hi, it all depends on the printer your using.
How to Scan a Document on a Multi-Function Printer
A multi-function printer with a scanner makes backing up your important documents easy. The scanner function of the printer allows you to translate a paper document like a receipt or title deed into an electronic copy that is stored on your computer. Once you have an electronic copy of your document, you can process and manipulate the document as you would any other electronic file. Follow these steps to scan a document on a multi-function printer:
Connect your multi-function printer and computer. Power them up.
Select the side of the document you are going to scan. Give the document a once-over, checking for any flaws that you do not want transferred into electronic form.
Open the printer's lid. Place the side of the document you want scanned face-down on the glass plate of your multi-function printer's scanning bed. Align the document to your satisfaction.
Close the printer's lid carefully. You may want to weigh the document down with another sheet of paper to prevent it from shifting.
Choose an appropriate scan resolution. You may have to do this using the controls of your printer or on the computer, depending on the model and software.
Press the scan button to start the process. This can be done on the printer itself or on the computer.
Preview the scan on your computer monitor. You should be able to make minor changes to the scanned image if needed.
Save the scanned image if you are satisfied with the result. Try again if you are not satisfied.
Tips & Warnings
Scanning documents at high resolution and low data compression will produce the best image quality at the cost of file size.
Not happy with a scan? Re-check the alignment of the document and try it again. Discard the duds when you get a scan that works for you.
Using harsh cleaning chemicals such as acetone or benzene can damage your multi-function printer. Abrasive cleaners are also not good on the machine, particularly the glass surface of the scanning bed.
....How to Scan a Document on an All-in-One Printer?
Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
Turn on your all-in-one printer and computer. Check the connections between the two machines.
Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
Close the printer's document lid slowly so the document does not shift position.
Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
Push the scan button. You may have to do this on the printer itself or on your computer.
Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
Accept the scan and save. Return the original document to a safe location.
Hope it helps..
Oct 28, 2010 | Office Equipment & Supplies
Mx canon mx320 wont scan, it just says pc scan standby, and thats it
You go on your computer open the start menu and go to devices and printers. Click on it. Click on your Canon Mx320 icon. Then it will say scanner management and you click on Scan Photos or Documents. The printer is just waiting for you to do it from the computer. From there you can preview the scanned photo or documented.<br /> <br /> Press "OK" in the printer as well.
Aug 09, 2010 | Office Equipment & Supplies
My hp 1401 wont scan ..it keeps printing out the test page so I was trying to get it to scan the page but it wont scan help
Make sure that the unit is not connected to the computer while scaning the alignment page.
Please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00473766&cc=uk&lc=en&dlc=en&product=1103491
:) Dr Tony
May 13, 2010 | HP PSC 1401 All-In-One Printer
When scanning a document, such document stays with the previous document scanned and wont save as a different file. How can I separate what I'm scanning from what I scanned previously on my computer? How...
If you had selected 'multipage' option, the scanner will convert all pages into a single page. Switch off (uncheck) multipage option and you will get individual page outputs. Check in the software if your clicked unnecessary button for saving in the last file. Try 'Default' button if available and try again.
Oct 16, 2009 | Bell & Howell B we Bell + Howell Truper...
Hp1350 wont scan press scan button on/resume light blinks buzzing for a few seconds and nothing else.
Did you try print any document just to make sure that printer is connected properly to the computer. If it is printing than try to scan from computer , i mean there must be a icon in your computer "Hp Director", open that and click on scan document. if that doesnt work, than click on start, got to run and than type "stimon.exe" than hit enter from keyboard. Nothing will happen , just screen will flash for a second, than try to scan. if it doesnt work than you have to unistall and reinstall the software
Aug 07, 2009 | HP Office Equipment & Supplies
Scanner hp psc 1210 all in one printer
Hi there.
As there is no full featured software available of PSC 1210 All-In-One for Windows Vista, we cannot scan from the All-In-One itself.
However, we may utilize the scanning functionality with the Microsoft Paint and Windows Photo Gallery on the computer.
I am providing you a weblink which would help in scanning with above mentioned programs.
Here is the weblink:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&cc=us&lang=en&os=2093&product=90764&dlc=en
Hope this information would be helpful.
With regards,
Ashesburn..
Apr 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
Scanning
go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00503569&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
Dec 17, 2007 | HP Photosmart 2575 All-In-One InkJet...
k24674
jasbo
jasbo
Marvin
Marvin
