Question about Dell 962 Photo All-In-One InkJet Printer
Left cartridge incorrect,what is that,what to do
    Guru:
  • 366 Answers
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Posted on Jul 17, 2010
Keeps saying my colour cartridge is missing
Problem
Wrong cartridge; Left cartridge incorrect; Right cartridge incorrect; Left cartridge missing; Right cartridge missing; Error 1205; Error 1206; Cartridge error; Cartridge incorrect; Cartridge missing
Environment
Microsoft Windows XP; Microsoft Windows XP Professional x64 Edition; Microsoft Windows 2000; Microsoft Windows Vista
Solution
Explanation
An 'incorrect cartridge' or 'missing cartridge' error can be displayed if:
    • The wrong cartridge is installed, or
    • The cartridge is not installed properly, or
    • The cartridge is missing.
What to do
X4850
http://support.lexmark.com/index?page=content&id=SO4738&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4875&locale=EN&userlocale=EN_US
Feb 12, 2018 | Lexmark X5270 All-In-One InkJet Printer
Error: right cartridge incorrect
Left Cartridge Incorrect / Right Cartridge Incorrect
  1. Remove the indicated print cartridge.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridge.
  6. If the error:
    • Does not reappear, the problem has been corrected.
    • Reappears, replace the print cartridge with a new one.
Jul 19, 2010 | HP PSC 2210 All-In-One InkJet Printer
Left ink cartridge incorrect. It is the right ink
A trick which may work is cleaning the contacts on both the cartridge and the printer.
Make sure you've switched it off first, I'd try gently buffing with a soft dry cloth first.
HP reccommend using distilled water and cotton buds, but not alcohol based cleaning fluids.
Allow the water to evaporate before replacing cartridge and switching on.
May 11, 2010 | Dell 946 All-In-One InkJet Printer
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
Hi, I have a Lexmark X7170 Multi-function printer/copier/scanner and it is showing an error message "left cartridge incorrect". I have not charged the cartridges and I have tried to re-align it. Any ideas?
it means your left cartiridge got some problem, might be it got short and you have to replace that.
try this remove your left cartiridge and then try to print if it work then its clear that your aother cartiridge is gone and you need to change it.
Oct 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
I have installed a black 23 print cartridge in my x3550 printer, and it is indicating that the cartridge is incorrect, however, this is the same cartridge that is required.
Left/Right Cartidge Incorrect - huh? The printer is saying Left Cartridge Incorrect or Right Cartridge Incorrect,
and you are sure that you inserted the correct cartridge, a #23 or #24.
A small number of #23/#24 cartridges will report as Incorrect Cartridge because
of a manufacturing issue. There is a firmware upgrade available to fix this problem, and allow
the printer to accept the cartridge.
3500-4500 Series (X3550, X4550)
3400 Series (X3430)
1400 Series (Z1420)
To apply the upgrade:
  1. Make sure the printer is turned ON and connected with a USB cable.
  2. Download and run the appropriate update program using the links above.
  3. Be careful not to disconnect or turn off your printer while it is being updated.
When the update is complete the printer should automatically restart and accept the #23/#24 cartridges.
Jun 18, 2009 | Lexmark X3550 All-In-One Printer
Newly installed Cartridge. Problem: "Left cartridge incorrect".
When you place the old cartidge does it give you this problem.try to clean the contacts on the printer and the cartridge it self.
May 03, 2009 | Lexmark All-in-One Printer with PictBridge
Printer says right cartridge incorrect. I know it's correct.
try cleaning the brown dotted circuit of both printer and cartridge. and then insert both the cartridge 1 by 1 and then check.
or sometimes it shows --replace left cartridge --- but both the cartridges are faulty and so its not working.
hope this helps you.
thanks.
Oct 11, 2008 | Dell 924 All-in-One InkJet Printer
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
128 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
