Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Wiring diagram for kitchenaid side by side refrigerator
4 Suggested Answers
  • 180 Answers
SOURCE: need a wiring diagram for a KitchenAid
It is either inside the kickplate, under the temperature control panel, near the comperssor, or some models have it on the back of the refrigerator.  If it is not in any of these locations take the model # to ap parts store and they should be able to order u one
Posted on Oct 25, 2009
aasc
  • 1606 Answers
SOURCE: KitchenAid Wiring diagram
http://www.servicematters.com may have what you need .
Posted on Aug 09, 2009
  • 137 Answers
SOURCE: I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
Posted on Nov 28, 2009
I have a Kitchenaide side by side frig and freezer. The freezer is a model KSCS251 and about ten years old. It has got a loose freezer handle. what do I need to tighten it.
There should be a few more letters and numbers in the model number. I suspect the 1 should be read as an I. Look up your model here: https://www.kitchenaid.com/customer-service/manuals/ .
For the KSCS25INMS03, there are set screw on the top and bottom of the handle for the freezer. The screws are visible from the side of the handle facing the refrigerator section of the side-by-side design. See the freezer door parts diagram for your model. One model parts diagram is here: https://www.kitchenaid.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10128953.pdf .
I hope this helps.
Jan 16, 2017 | Refrigerators
Tip
KitchenAid, Whirlpool side by side refrigerator remove the main control board...
Electrical Shock Hazard
Connect green ground wire to ground
screw.
Failure to do so can result in death or
electrical shock.
REASSEMBLY NOTE: Be sure to reconnect
the green ground wires; one to the compressor
terminal, and the other to the chassis (see the
previous steps).
7. To remove the main control board assembly:
a) Remove the unit compartment cover
b) Remove the two hex-head screws from
the rear of the main control board assembly
enclosure, and position it so
you can access the board.
c) Remove the wire connectors from the
main control board assembly.
KitchenAid, Whirlpool side by side refrigerator Component Location and removing cover
http://www.fixya.com/support/r5759997-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method A
http://www.fixya.com/support/r5760017-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method B
http://www.fixya.com/support/r5760029-kitchenaid_whirlpool_side_side
on Aug 27, 2010 | Refrigerators
Ice maker will not make ice. everything in installed properly. unit is 7 years old. red light flashes twice, then pauses and flashes twice again.
in the door ice storage. this is complicated. might check at the bottom of ref. there is a removable toe panel and on the back of the toe panel usually there is wiring diagram & mini manual to help diagnose icemaker problems.
Jan 03, 2010 | KitchenAid KSSS36QK Side by Side...
Compressor wiring digram for kitchenaid refrigator fsrs25qdwh03
Good day,
You can go here to see the basic wiring setup of your terminals for the compressor along with the relay and overload.
http://www.jimdow.com/jimdow/sales/diagrams/refcopressorterm.jpg
L1 andL2 can be interchanged, since it is alternating current.
Basically, the overload is clipped to the body of the compressor, and is wired to the top center pin (common).
The relay, is pressed onto the R & S terminals. L1 or L2 can be used to connect to the overload terminal. The unused one is connected to the R side of the relay.
In addition, there is a run capacitor that is jumpered between R & S.
Actually it is an accessory to improve the effeciency of the compressor. It would run without it.
Hope this helps..
Thanks for using Fix Ya
Dec 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Need a wiring diagram for a KitchenAid refrigerator KSCS25I
Oct 25, 2009 | KitchenAid Refrigerators
Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Nov 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Oct 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Door front water and ice inop
the bord is usually where the switch's are in front. There behind the push buttons. I would make sure your getting power to the bord and go from there. If you do have power there replace the bord. If not you will need to locate the tech sheet for the wireing diagram and trace the circut for the dispensor. Good luck
Jul 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
185 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
