Question about NetGear EN104 Networking Hub
Conflict message ;When we hook up the dsl and 2 pcs to the hub we keep getting the conflict message. ...another computer on this network has the same ip address. Have set both computers to get ip auto same results. No other connections to hub..........
    Guru:
  • 1,481 Answers
If u have 2 PCs connected to the hub/router then you must specify the IP address in Network Connection wizard..../ LAN properties / TCP-IP setting Tab......set each PC different....IP address
say like this.....
192.168.1.3 for 1st PC
192.168.1.5 for 2nd PC
the rest of the settings is based on you internet service provider
this will work....
Posted on Jul 15, 2010
Network
Most times this is because the computers have differing sub-net masks and/or IP addresses have differing roots. A simple solution is to set all computers to use DHCP to get their network addresses.
If you post the IP addesses and sub network fields for each machine I can be more precise.
Mick
Nov 19, 2013 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
I have a message that say Ip address conflict, what can I do
<When we hook up the dsl and 2 pcs to the hub we keep getting the conflict message. ...another computer on this network has the same ip address
One of the PCs might have a static IP address. Go into the TCP/IP properties for both PCs and make sure they are set to dynamically obtain IP addresses. Then reboot the PCs and the hub, and you should be okay.
Are there any other devices on your network? They might be the ones with the conflicting IP addresses. Any iPods, TVs, or Wii's?
Jun 21, 2010 | NetGear EN104TP Networking Hub
The internet connection is fine (DSL AT&T).
1. You may have a an IP address conflict.
2. check the device connected to the router
all computer need to be connected at the same time.
3. Bring all the computers up one at a time and this should resolve the address conflict.
May 16, 2010 | Linksys WRT54GX4 WIRELESS 802.11G...
Trying too hook 2 computers and a xbox 360 all on the same network..ip address...when I plug them in it tells me I have a ip address conflict
Check to make sure neither of the PCs have a static IP setup, and reset your router back to factory default.
May 01, 2009 | Computers & Internet
Playstation 2 not connecting to the internet
the router you are using is not comp with the ps2 try using linksys or belkin
Nov 30, 2008 | Dynex DX-ESW8
Connection problem
If I understand what you're saying, you need a router.
See here for an explanation"
http://compnetworking.about.com/od/homenetworkhardware/f/routervsswitch.htm
Nov 04, 2007 | Computers & Internet
NetGear EN104 Networking Hub Logo
123 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
