I installed a Mr. Slim system and 2 of the 3 units work fine. The third unit will turn on, but doesn't activate the condensor. In a few minutes the left light begins flashing. I put a multimeter to the outdoor unit and tested the voltage to the indoor units and each combo of wires showed about 240V until I tested the S1 and S3 of the suspect unit and it only showed 120V. Is there a simple solution to this or is possible problem with the circuit board. Thanks!
Hi, Try to turn all of the power off for a few minutes and then turn it back on...this should reset everything again... If not you will need to get a tech. to check it all out...
Here is a tip about Mitsubishi Air Conditionersand how to get the manuals for all of the Mitsubishi line. The manual includeboth troubleshooting and installation.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
the light blinking is an error code. you can count the number of blinks from a brief pause. it would continue to blink the same number of blinks after a brief pause. count this blinks and you can help the incompetent person that installed your unit to diagnosed the unit from the error codes that you will give him.
if you unplug the unit, it will reset and run again. after a few minutes, the sensor would sense the trouble and turn off the unit and display this code again as a blinking light.
