Question about Sony Playstation 3 (PS3) Console
When i turn system on and hit reset red light comes on and system won't eject disk
  • 206 Answers
Well the same thing happened with mine only it was the RROD but in order to get the disk out
1. turn off the switch in the back
2. hold the power button down AND the eject button at the same time
3. and while you are doing that reach around to the back of the system and turn the switch back wait 1 second and the fans will kick on
THE DISK SHOULD COME OUT IF NOT PRESS THE EJECT BUTTON
HOPE THIS CAN HELP!!
Posted on Jul 15, 2010
PS3 stuck on red light after it froze up. I unplugged it and replugged it and it's still stuck on the red light. It doesn't change or anything even after hitting the power button.
It would help, if you posted the model number of your system, as they do vary sightly. Is there a disk inside they system? This could be the main problem in witch there are several solutions to remove it. If not, than try inserting a disk, as the PS3 auto recognizes a disk being inserted and turns on the system. If the light is on, and it wont let you power it on, then generally it's the stuck disk problem. ^^ Hope this helps, and good luck.
PS3 Slim Manual Eject for Stuck Disc
Sep 23, 2015 | Sony Playstation 3 (PS3) Console
WD external hard drive mac
Sounds like your external drive might be bad. Try connecting it to another system and see what happens. If you can't get to read data on another system, the drive is bad.
May 29, 2012 | Western Digital My Book Essential Edition...
Samsung blu-ray won't load or eject
Someone is going to have to open it and look to see if the disc inside is out of position or jammed in some way----sometimes you can gently move it a little back into the position where it will eject the disc--which could be your entire issue.
May 28, 2012 | Televison & Video
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
The power light flashes red on/off. When I turn it on it stays on for a brief moment. There is a disk inside and when I try to press eject it makes a noise like it wants to eject but doesnt.
i do know a way to get the disk out
1. power the console off by the switich in the back
2. Hold down the power button and the eject button
3. while holding through down reach around to the back of the console and turn on the console
4. you will here the fans kick on which means that it is trying to clean out your system then the disk should come out!
soory but thats all i can help you with i hope it works and good luck!!
Jul 08, 2010 | Sony Playstation 3 (PS3) Console
I have playstation 3 model # CECHH01, a game is inside, when i power on the light goes green, then quickly goes blue then yellow and goes back to red and powers off leaving the red light blinking. What do...
well sounds like your PS3 needs to be reflowed or reballed. I would highly recomend you have a professional do the repair. as fas as having a game stuck inside the machine you can get it out in under 10 seconds by doing this.<br /> <br /> 1) turn off power switch in back of ps3<br /> 2) place finger on eject button and hold there while ps3 is off ( no red light) <br /> 3) while holding finger on the eject button turn power switch on the back of ps3 on , hold finger on eject button untill the disk ejects.<br /> 4) turn power switch off and have unit repaired or replaced. <br /> <br /> if unit is covered by warranty and you send it to sony you must get your disk out of the system as you will NOT get it back if you send it to sony. Most reputable repair shops will return your disk with the system or give it to you before they take the system in for repairs. I ALWAYS give the game disks back before a customer leaves my shop as it leaves me with less to keep track of.
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
My console starts to turn on ,then shuts down!!!
try reseting your video settings by holding the on;off button for about 5 seconds when turning on . if this doesn't work, must be a problem with your hardware. then you should take the system to a support centre.
about the disk, have u tried to turn the system on by pushing directly the eject button ?
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
Stuck game wont eject
Try tilting the wii at several angles. The disc may come out. If not try hitting the eject button at several angles.
If all the above fails, this(although risky) may work.
1. find another disk.
2. slide into slot, just enough to get under the cd(NOT ALL THE WAY IN)
3. lift or puch down on the disk depending on the side the new disk is on
4. hit eject while lifting or puching.
5. If this does not work the system may need to be sent out
Nov 02, 2008 | Nintendo Video Game Consoles & Games
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Sony Playstation 3 (PS3) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
