Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Cp150 capacitor Where did you access this capacitor? I have removed the rear and front covers but don't know which board to look at. Thanks
    Scholar:
  • 146 Answers
The "C" stands for "capacitor" and the "P" stands for power. so look on the power/deflection pcb that is on the left as you look at from the rear.
Posted on Apr 23, 2008
How do I replace the CP150 on an RCA D5219 52inch rear projection?
You must know how to Solder,you will have to unsolder the capacitor and resolder in the New one
you also need to replace 3 capacitors CP150 CP114 CP120 they are all in the Same Circuit.
They are on the deflection Board which is the Bottom lefthand side and will have the FBT flyback Transfomer.
Mar 08, 2011 | RCA D52W19 52" Rear Projection Television
I am getting three flashes and then the tv goes off.
Remove the back panel from the television, you will see a board where the input jacks are located. To the left you will notice a red power wire. Just up and to the right approx 7" or so you will see a [_] shaped metal shield surrounding a capacitor in the middle of it. The part # on the board is CP150. It is a green/gold 16v 2200uF capacitor. More than likely this capacitor is faulty. Run your finger over the top of the capacitor, if it is beveled rather than smooth you have a definite solution to your problem. You may need to remove the plastic piece that covers the transformer to the left of the capacitor to gain easy access.
Dec 16, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turn itself off
On your front Panel board take contact cleaner and clean all of the contact switches,RCA is well know for having dirty or bad contacts
Power,ch- ch+ vol- vol+ another problem is Bad capacitors on the deflection board. cp114 cp120 cp150 1000uf 16v use 25v other 2 caps are 220uf 35v
Aug 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can anyone explain the step-by-step replacement of CP150 capacitor?
The cp150 is located on the deflection board.( far right side circuit board) You will have to remove the deflection board and unsolder the old CP150 and then resolder in the new CP150. Observe polarity. Also should repalce CP114 and CP120 with the CP150. You can get that repair kit at www.tvrepairworld.com which has the three capacitors, and the CD with detailed instructions with photos. The CD also contains the service manual and other service information.
Dec 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
It turns on and off.
Clean front panel Contact switches you will have to remove front middle board holding . Use contact cleaner only.You also could have capacitors going bad cp150 cp114 cp120 on deflection board cp150 is 2200uf 16v other 2 are 220uf 35v.
Sep 16, 2009 | RCA HD52W59 HDTV Projection Television
D56W - When it is plugged in I hear a
There is a capacitor on that board(cp150) that is very common to go bad. The top of it blows up so it is easily identifiable. Unfortunately, you can't see it from your viewpoint because it is located behind a heatsink toward the front of the board. I would bet that is what is wrong with your set.
Jul 06, 2009 | Televison & Video
TV CUTS OFF AND THEN COMES ON BACK FOR ITSELF
There is several reasons why tv shuts off/on It could be in Deflection board,SSB board is well know to cause muti problems cost of that board if you can find one starts at $252.00 - Deflection board $197.00 Ck all capacitors cp150,cp114 cp120. if cp150 is puffed up on top it is bad so replace all 3 caps.
Jan 05, 2009 | RCA D61W20 61" Rear Projection Television
Rca d52w20v 52 in proj tv
The capacitor you are looking for is on the Deflection Board on bottom is 2 boards on left is Deflection board on right side is SSB board it has the turners on it.cp150,cp114,cp120 these are the 3 capacitors to replace if cp150 is puffed up on top.
Jan 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 52in. rearprojection tv monitor
Remove the back panel from the tv where the input jacks are located. You will see a red power wire. Just above that and to the right approx. 7" or so you will notice a [_] shaped metal shield surrounding a cgreen/gold capacitor. You may need to remove the plastic cover that is located directly above it about 6-7" in length to gain easy access. Run your finger over the top of the capacitor. If it is beveled rather than smooth you have found a definite solution to your problem. The part number located on the board is CP150 16v 2200uF capacitor. It will look like a tall cylinder. Good luck!!
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
