Sleeve stuck in door of samsung washing machine, only noticed after i had started the machine. I stopped it immediately but now the door will not open
    Champion:
  • 207 Answers
You got to turn of the machine and wait for electric lock to release (unlock) the door. Usually no longer than 5 to 10 minutes.
Posted on Apr 20, 2008
Washer/dryer on spin fast but keeps stopping and starting how do I open the door?
If you sure that its not full of water, you should set the program to the stop position, and wait a few mins for the lock to release.
Jun 04, 2016 | Washing Machines
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
Problem with Hotpoint Washing Machines Samsung
ND -not draining. There could be something is stuck in the drain pump or one of the hoses connected to it( normally a coin is stuck in the L-shapped plastic connector to the drain hose)if the system is clear,then I would replace the drain pump.
Nov 02, 2013 | Samsung Washing Machines
My washing machine will start up but stops immediately and cut off
Good Afternoon Toni, thank you for your inquiry! Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Aug 04, 2013 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool awm 6145/3 washing machine. Door shuts cycle starts but within about 5 seconds it stops and door open light comes on.
your door safety switch may be to blame,, if its faulty the machine gets a notice that something is wrong and stops,, to check that try this link http://www.partselect.com/Virtual-Repairman.htm
May 31, 2011 | Washing Machines
Door Wont open on my Samsung J845 washing machine
yes its the door mechanism Unplug the machine for 4 hrs the try opening the door.Don't try to force it you will make matters worse
Sep 07, 2009 | Samsung WF203ANW Front Load Washer
Washer stuck
i am assuming that water comes in at the start of cycle and machine does not then progress. Points to a timer fault unfortunately. These timers are expensive and quite hard to fit. don't recommend repair in view of age of appliance.
honestly can't see how related to sock problem
Jun 26, 2008 | Washing Machines
Kenmore Washing Machine
check the lock switch on the front load washer sometime it gets stuck
Mar 18, 2008 | Kenmore 44042 Front Load Washer
Spin Cycle
The tub will come to a very quick stop when there is nothing in the machine. The breaking noise is the nylon break pads in the break assembly. This noise can be stopped by putting talcum powder into the break assembly. As far as the machine stopping and smoking ? I suspect a stuck/partially stuck break causing the belt to slip and heat up.
Nov 08, 2007 | Maytag Performa PAV2200
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
