Question about Kyocera Office Equipment & Supplies
Just brough a used Kyrocera CS 3050 - DP 700 is not reading that paper has been placed in the tray. Cannot scan. No error reading on screne. It seems as though there is no power to the DP 700. Checked connections and pins - all seem fine.
    President:
  • 1,561 Answers
The first thing you will need to do is to makesure the kyrocera receives power, because if there are no power to the unit, it can not function, when you power it on, did it power on, if no, check another AC outlet, if not still power on, check the cable that connects the device to AC source to see if it receives power, if there is power to the cable, it mean your device will need to be diagnose because this could either be power problem, or a faulty board. But if the device is not receiving power from the cable, it means you will need to get another cable in other to power on the device.
Take care.
Posted on Jul 15, 2010
  • mcgeelaw508 Jul 15, 2010
    AC power is fine. Lower unit is on and printing. Upper unit, DP700, is not working at all. Cannot scan nor photocpy from upper unit.
  • Sulaimon Jimoh Olayemi Jul 15, 2010
    The problem with the upper part could be that the fuse is blown, i would advice you check the user manual to locate the fuse on the device and replace it, the fuse is a white cylindrical small tube.
    Take care.
Our Panasonic WORKiO 1520 copier is giving us the error message
try and place the paper back on the tray properly for the censor to pick it i encounter this problem everyday but i just reset the paper.
Oct 12, 2012 | Panasonic WORKiO DP-1520P All-In-One Laser...
Error code C0320 for cs pro 3050
Please deescribe your roblem/reset the malfuntiion code open and close the front door or turn OFF the power witch and tray again to turn .
Aug 13, 2010 | Minolta EP4000/5000 CS/PRO Copier
E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
May 07, 2010 | Panasonic DP-C213 Color Copier
Hp 3050 scanning error message
Good day!Try to check the feeder if it has paper on it..then try on and off the printer until it holds normal status..
mastergani
Mar 29, 2010 | HP LaserJet 3050 All-In-One Printer
Kyocera fs-1920 printer fault
if the machine is starting up and you just replaced the toner cartridge make sure it is seated properly also did you shake the cartridge slightly before fitting sometimes the cartridge can compact the toner and it doesnt agitate to the dev unit properly. check also if the dev unit has been reset properly and the lever set in place..
Apr 27, 2009 | Kyocera Copystar CS-1620 Black and White...
Panasonic DP 2500 paper tray error
Make sure that you don't have too much paper in the tray. There is an overfill idicator on the back of the tray. Push the tray in firmly. Then try to print. If not, reset the printer by pushing "reset" button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 21, 2008 | Panasonic Workio DP-2330 Printer
Missing Toner Cartridge
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Sep 23, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 No paper pickup
My printer now spits out the paper all over the place and jams up all the time. Did not happen when I first got my 3050 a few months ago.
Jun 06, 2008 | HP LaserJet 3050 All-In-One Printer
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
HP Laserjet 3050 paper jam
The rollers may be worn so it is not getting picked up evenly. Also, be sure that your paper tray in aligned properlyand guides are keeping the paper straight. If both of these seems to be good then there may be something in the paper path.
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
35 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
