Question about Dryers
I have a kenmore 80 series electric dryer. The dryer is spinning but not heating. I have replaced the heating element and High limit thermostat and the dryer is still not heating
    President:
  • 1,653 Answers
The best thing to do is a continuity check on the AC supply from the main supply through to the heating element and determine where the fault is.
Posted on Jul 15, 2010
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
There is no heat in my Kenmore 80 series dryier. The drum is spinning and it seems that there is an air flow coming through, it's just could. The brakers are fine (there are two of them and they are...
The problem is in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Click on the link below for the details.
Troubleshooting an Electric Dryer Not Heating
Jan 19, 2011 | Kenmore Dryers
Kenmore elec dryer series 80 not heating up
The problem is in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Dec 18, 2010 | Kenmore Dryers
Heat does not stay on
Check the high limit thermostat. You can check it using a multimeter or ohmmeter. If bad, replace it. Hope this helped.
Jul 18, 2009 | Kenmore 800 7983 Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
My Kenmore 80 series electric dryer won't heat. I
The bottom limit is engineered to open at 250F and the small top one is supposed to open at 300F. The bottom did not have time to click in and so it is considered weak. the kit comes with both thermostats in it Part number 279769
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 07, 2009 | Kenmore Dryers
Kenmore Electric Dryer
If this is a Kenmore, have you checked the thermal cut-out or high-limit thermstat? Does the drum turn when you start the dryer?
If the drum turns, but does not heat, you will need to check the thermal cut-out (located on the heating element housing). The TCO should read a SHORT (0 ohms) or very low resistance. If it is OPEN, replace it along with the high-limit thermostat. In most cases the two components are sold as a set and are recommended to replaced as a set by the manufacturer.
Reason: The TCO is designed to protect the heating element and thermostat in the event of an overtemp condition. If the TCO is bad, there's a likely chance that the thermostat could be damaged.
If the TCO reads good, you may have a thermostat that is failing. The high limit thermostat operates normally in the CLOSED (shorted) position and will OPEN at or around 157 degrees F. It is located on the heating element housing adjacent to the TCO. If the thermostat has failed the dryer will tumble, but will not heat. Follow the same recommendation as for replacement of the TCO. Replace both components as a set.
Now...if the dryer drum does not spin, the likely cause is the thermal FUSE. It will be mounted on the blower housing near the blower fan. It is usually white (plastic) in color on Kenmore models. It should read a SHORT. If it fails the dryer will not spin or heat.
Post back with your comments or questions. I hope I'm leading you in the right direction.
Jan 15, 2008 | LG WD-14124RD Front Load Washer / Dryer
Dryers Logo
195 people viewed this question
Top Dryers Experts
Marvin
Marvin
