Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
I have a flat panel lcd 19, it doesn't power on
I have a flat panel lcd 19'' monitor Westinghouse, it doesn't power on, is dead no light or anything, I opened the monitor but I don't see any capacitor blown, I don't know what to look for, any ideas??
  • rghouseholde Aug 03, 2010
    Yes, thank you for writing me back, I bought a new power board DAC-12M030B, but still no power, no LED, any ideas???
    President:
  • 670 Answers
Don't know what model you have, but I would check the fuse first. It should be marked with a Fxxx where xxx are numbers. Sometimes the fuses are glass, others times they look like little surface mount chip types. If you find that a fuse is blown, does not mean that just replacing it will solve the problem, you need to figure why the fuse has blown, typically the FETs short out. Hope this helps.
Posted on Jul 15, 2010
  • rghouseholde Jul 15, 2010
    I checked the fuse and it seems fine, when you say" FETs short out" what part is that?? Sorry I'm not too savvy with specifications, I don't have a manual, but if you could be kind to tell what FET means, I 'd appreciate it.
  • Stephen Lam Jul 16, 2010
    A FET stands for a Field Effect Transistor. It typically comes in a square dark plastic package with a metal tab on the top. It connects to the board with 3 leads. They are typically used to drive the backlight transformers. When they fail, the LCD goes dark. You can check them with a meter, to determine if they are open or shorted.
I have model 1975NW. When power is turned on, green light appears, then orange light. No picture is present.
The ORANGE light indicates "power-saving" mode -- when no "output" from a video-card is being detected, the screen will dim itself. Try a different monitor. Try a different video-card in your computer. Try your monitor on a different computer.
Feb 03, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
Jan 20, 2011 | Computers & Internet
Light on monitor turned to blue
Sorry man! You have defective monitor. Consult the workshop
Jun 04, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
I am powering up and the flat screan turns on and
More likely to be bad caps (bulging top/seal) in the power supply, which when they failed, they may have taken out the inverter fuse on the transistors in the inverter circuits also. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
The monitor will not come on. The indicator light just stays on red. We will unplug it and plug it back in, the power indicator light will flash to green then return to red.
You will more likely to have bad caps in the power supply which when they failed, will take out the fuse and MOSFET in the backlight inverter curcuits also. See example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Power light is on but there is no picture on monitor.
Very common problem with these LCD monitors. You have a blown power supply for the backlight circuit. If you are comfortable with elecronics repair/soldering I can walk you thru opening the unit and repairing it. If you don't want to do it yourself we have a repair option available for $35.00 plus return shipping.
Buddy
Corporate Computer
318-447-9040
Over 21 years in PC and printer support/repair
Jun 18, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Buttons on the bottom of the westinghouse monitor
momof3boysn1, Did you try removing the plug from the outlet strip and then plug monitor back in and turn it back on? Usually the button that looks like an asterisk with a small circle dead center will be the brightness control. get back to me if this won't help. I'm louie12fix on fixya or lmistyrel@ aol.com
Apr 05, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
554 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
