Question about Amana Heating & Cooling
How do I open the goodman condensing unit for cleaning
How do I open the goodman condensing unit to clean out the grass clippings between the cabinet and condensor coils
  • 57 Answers
I suggest taking the top screen and possibly the condenser motor out. If you try to take off the cage that surrounds the unit, you may not get it back on right. Best to push the dirt out with a hose from the inside out.
Posted on Jul 16, 2010
Troubleshooting guide
It is normal for properly maintained AC unit to condensate, as the coil drops below dew point it will condensate the water in the coil cabinet and water should flow out condensate drain.
causes... drain stopped up .... correction.. clear drain. Other causes could be low air flow... Dirty Filter.. Dirty Coil ... Obstructions to discharge air grills closed or blocked... others
could be improper Refrigerant charge, Dirty blower vanes blower cabinet not level. All things easily corrected with a Service call by a reputable service company. Good Luck I hope this helped you.
Aug 11, 2014 | Goodman Heating & Cooling
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
Nov 06, 2013 | Fujitsu 18C1 Air Conditioner
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
Goodman GSC130421ab has no voltage to contact after washing coils....it worked just before powering off unit at diconnect to clean the condenser coils
very posisble.check the fuse on the board on the indor unit. replace with equal size fuse (not bigger probably 3 amp). if the indoor unit comes on then the fuse is fine and i would suspect the coil on the contactor has shorted
Oct 02, 2012 | Goodman CKL36AR36 Air Conditioner
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
Outside unit doesnt start inside unit is working
This model of Goodman A/C the condenser coil get extremely dirty and what happens is when your condenser runs for a long period of time it pops the capacitor. This is the starting component for the compressor and the fan outside. the coil needs to be cleaned with a non acid condenser cleaner. Open up the side compartment of A/C look at the silver cylinder thats the capacitor if is looks swelled replace it.
May 11, 2011 | Goodman CKL30AR30 Air Conditioner
Its gets up to100 during the day here right now. my ac is set on 78 and comes on at noon and does not turn off till at least midnite. the temp on the thermostat stays at 80 untill after midnite. ...
Check the outdoor unit you should have hot air discharging out the top of the condensor. The insulated suction line should be sweating. The inside
coile should be condensating and water should be flowing to a drain from the indoor unit.
If all of that is happening, then I would say you now
have a ubdersized unit. If none of that is happening
then I would say you are low on refrigerant.
Jun 24, 2010 | Goodman CLJ30AR32 Air Conditioner
High head pressure, normal suction pressure? what r some things i can check for?
Dirty condenser or slow or not running condenser fan. What are the pressures?
Jun 28, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
69 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
