Question about StumbleUpon Social Network
My iece is running wildand I do not wantb st see her life go dow the drain
  • 5,568 Answers
If your niece has reached adult-age, she is on her own; if not, i is up to her guardian to try to correct her course in life.
In any case, this is a poor venue to try to get help, since it is involved in repairing 'things,' not lives. I wish you (and her) luck-
Posted on Jul 15, 2010
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
3/4 hp pool pump and gas heater won't run. Both are on a 30 amp breaker. power goes to the pump and heater but nothing runs
USE A VOLT METER , START AT THE BREAKER AND WORK YOUR WAY TO EACH DEVICE. THIS WILL HELP YOU TRACK DOW THE POWER ISSUE .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 18, 2012 | Pool & Spa
Water in bottom after running. Dows not drain properly
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 11, 2010 | Electrolux 23 in. ESL6114 Built-in...
THE WATER KEEPS RUNNING AND NOT FILLING UP
That means it is running out somewhere. The outlet hose is probably too low down.
Sep 06, 2010 | Washing Machines
I am replacing the original 2 prong power cord on my B&K ST 140 amp.I have installed a 3 prong IEC male connector in the back of the amp. The middle prong of the IEC connector is for ground. I plan to...
'L' is for line, or the 'hot', 'N' is for neutral. If the old cord had a polarized plug (one wide blade, one smaller), then yes it matters. The wide blade is neutral, the smaller one hot. If they are both the same, and the wires just connected directly to the primary side of the power transformer, then it does not matter.
Feb 05, 2010 | Audio Players & Recorders
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Washer is running properly but a code will flash periodically. Code:EFO. What does this mean?
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 05, 2009 | Frigidaire FTF530E Extra Large 3.1 Cu. Ft....
Stuck on rinse
Check drain hose under the tub by unscrewing clamps to see if there is any blockage in this pipe; also clean out filter in this area. Disconnect from mains before doing so.
Apr 20, 2007 | Frigidaire FTF530E Extra Large 3.1 Cu. Ft....
StumbleUpon Social Network Logo
47 people viewed this question
Top StumbleUpon Computers & Internet Experts
Computer Links
Are you a StumbleUpon Computer and Internet Expert? Answer questions, earn points and help others
