Question about Sanyo DS25390 TV
How to program my sanyo tv
How do i program a sanyo fxrf remote control to my sanyo flat screen
You don't program that remote. It isn't programmable. It's a replacement remote for a specific range of Sanyo TVs: The FX- and GX-series Sanyo TVs.
If your Sanyo TV is not an FX- or GX-series set, then you bought the wrong remote.
Sep 08, 2014 | Televison & Video
I need the code to program a sanyo tv using the one for all untiveral remote URC-2060
If you do not have the code for you Sanyo TV then you can use the remote itself to get the code. It is a bit painful as you have to count the number of blinks it makes.
Follow the steps under getting your code.
Also it would help if you provide the model number of your sanyo TV in the comments section.
How to Program your One For All remote
Aug 17, 2014 | Televison & Video
SANYO REMOTE MODEL: FXWD - PROGRAMMING MANUAL
The Sanyo FXWD remote was used with the Sanyo DS27930 and DS32424 TV. The manual for the TV is available at manualslib.com. The instructions for the remote are on pages 7 thru 11 of the TV manual.
Mar 28, 2012 | Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need the code to program my sunflwer remote with my sanyo tv
try these 014 / 032 / 045 / 075 / 120 / 121 / 122 /123 / 124 / 163 / 168 / 171 / 183 / 196 / 206 / 305 these are for all diffant sanyo tv and if your remote needs more than a 3 number code sorry can not help
Nov 28, 2009 | Sanyo Televison & Video
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
Set t.v /remote to work with other components
Do you have a Sanyo Universal Remote ? If not, you program your dish 500 remote for these.
Sep 16, 2009 | Sanyo DS31590 31" TV
I need the codes for a sanyo tv to program my philips universal
please find the similiar type of the tv (must good tv) remove both tv memory ic and copy from the good tv.use memory ic copier all settle ok
Jun 06, 2009 | Sanyo DS27800 27" TV
I have a rca 311 w to program into a sanyo tv
Code For Model RCR311W
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Jun 05, 2009 | RCA RCR311B Remote Control
Need codes for sanyo tv
I HAVE A UNIVERSAL REMOTE CONTROL AND A SANYO TV
TO PROGRAM WITHOUT THE BOOK OF CODES. HOW CAN I GET THE CODE TO PROGRAM THE REMOTE CONTROL FOR A SANYO TV ?
Mar 13, 2009 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
