Can you please help me get Error codes and svc modes documents for the toshiba e studio 165.. Thanks
    President:
  • 1,561 Answers
There are series of different error on this issue,
error L-1 means that u have problem CCD MCU Harness Disconnected.
error c390 occurs due to :--
either any of the dorr/drwarer is open in the unit.open and close the door drawer and check out.check out for any loose wire or paper jam in the unit.if all other thing is proper
then This is a fuser temp error. or the laser assembly problem in the unit.
error code c467, how to clear it, Hello sir; Hold down "0" &"8" while you turn on the power, enter 400 press "enter" or "interupt' key then turn power off and back on again.
I would suggest you check the the links below to search for the user manual that will explain more on this error codes.
manualsonline.com
Type the above link to search for the manual of your device, the link contain almost all the manuals of all device.
OR
http://printer1.blogspot.com/2009/02/toshiba-e-studio-16p-service-manual.html
Take care.
Posted on Jul 15, 2010
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
How con i INCREASE , color of copy in toshiba 452
please sent to my add the GUIDE code toshiba 452
oolmii@yahoo.com
Aug 12, 2012 | Toshiba Estudio 200L Copier
TOSHIBA E-STUDIO 161 error code show mw H and 4
How are you this is jack my id jack_pak@hotmail.com
your copier toshiba 161 show H...4
Dear, Follow the procedure.... press C(CLEAR) BUTON+ PHOTO BUTON+C BUTON+PHOTO BUTON..... Your copier enter special mode
Then you press 14 and start key.... copier ...ok
PLEASE VOTE ME
Thanks,
Best Regards,
Aug 31, 2010 | Toshiba e-Studio 161 Copier Copier
After switch on the toshiba e-studio coming uo
please do the following..
  • Open the ADF cover.
  • If shipping tape is present on the blue document feed-guide assembly, remove the tape.
  • Using the blue handle, lift the ADF rollers.
  • Remove the document.
  • Lower the ADF rollers.
  • Press the two tabs on the document feed-guide assembly to secure the assembly into the proper position.
  • Close the ADF cover.
  • Fax, scan, or copy again.
  • Jan 20, 2010 | Toshiba e-Studio 232 Black and White...
    Error code L
    L signal is scaner lock
    please chack your copier left side copy board under lock unlock mark
    Thanks
    Tareq
    Mar 05, 2008 | Toshiba e-STUDIO 150 All-In-One Laser...
    Error code in E studio 150
    Hello! I did it and it worked perfectly.
    I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
    Feb 19, 2008 | Toshiba e-Studio150 Copier
    Toshiba E-Studio 160
    When the message call for service is displayed
    press the C key and the 8 key at the same time
    an alpha numeric code will appear eg: C47 etc
    Post the error code and I'll tell you what it means
    Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
    Hard Drive error No. F105
    F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
    Dec 30, 2007 | Toshiba e-Studio 350 Copier
    27 people viewed this question
    k24674
    Marvin
    Marvin
