Question about Price Pfister Home
Water changes to hot while showering - Price Pfister Home
    Problem Solver:
  • 3 Answers
It can be that your geyser is not sending enough cold water to the pipes of your shower so you should check the sensitivity of your tap/valve. it happens sometimes that the tap turns as the water comes into contact with it. it can also be that cold water is used by someone else that also uses your geyser's water
Posted on Jul 15, 2010
3 Suggested Answers
  • 659 Answers
SOURCE: low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Posted on Apr 05, 2009
  • 297 Answers
SOURCE: Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Posted on Jul 26, 2009
Moen single handled shower the hot water turns cooler then cold after a minute
Your whole house is likely plumbed wrong so that it is impossible to have equal pressures of both hot and cold at your shower. If you had your home plumbed with aquapex using a radiator for the hot water and a radiator for the cold water and have the radiators fed with a 1 inch line you can have close to perfect pressures.
Nov 15, 2013 | Moen Home
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
Hot water not working
Might need to change hot water element. In hot water heater. Not too bad to change.
Jun 28, 2013 | Home
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Jan 14, 2013 | Moen Home
Good afternoon, We have a 25yr old delta shower faucet and head. both work wonderful but the water is not all that hot- our new hotwater tank is set at 130 degrees. If i need to change the mix do i do it...
You don't change the setting on the faucet or behind the shower wall. You change the mix in the hot water heater itself. New hot water heaters are set at a relatively lower hot-water-setting for liability purposes. To achieve a hotter mix, take the cover plate off the hot water heater. You will see a dial setting that allows you to turn up the heat. Depending on what type of water heater you have, there might be two cover plates (lower and upper). If so, you'll need to adjust both of these.
Feb 26, 2011 | Delta T13420 Chrome Classic Single Handle...
I have a new moen single handle shower faucet that is only giving one temp of water (cold). Only if I have it on very slow will I feel hot water. Any idea how to fix
Did the hot water shut off get turned back on fully after the change? Is the hot water line kinked under the sink? Is the hot water shut off valve working?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 05, 2009 | Moen & One Handle Tub & Shower Faucet
The shower just give off piping hot water
Is it hooked up to a hot water line? Change it to a cold line.
Jul 05, 2009 | Henri Studios Henri Studio Summer Showers...
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Apr 16, 2009 | General Electric GE SmartWater Household...
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Home Logo
148 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
