Question about Euro-Pro 8260 Mechanical Sewing Machine
Older singer machine model 417. Problem winding bobbin - the thread cutter does not engage when you start winding the bobbin. Then bobbin winds a few rounds then slows and comes almost to a stop - the thread winds in an asymetrical pattern.
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
dupina
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 4 Answers
SOURCE: Birdsnest and machine jams
I have a singer 457 (from 1964!!) that I inherited from my grandmother. It worked successfully many months, but then I developed a similar problem (birds nests, tangles in the bobbin assembly).
AFter messing with the tension, different spools of thread, and what not, I found that it was the BOBBIN that was the problem. Althought this bobbin is the same size and shape as others, there is something about it that knots up the inside of the machine EVERY time (as in within 15 stitches or less).
I tossed the thing and have been trouble free ever since.
I am now convinced that bobbins (particularily plastic ones) wear out.
Posted on Jan 27, 2009
SewTechWayne
  • 186 Answers
SOURCE: problems winding bobbins on my singer 4622 sewing machine
I have two possible solutions:
1. you have the wrong bobbin and it doesn't grip the winder.
2. the small spring on the winder spindle is missing or bent, it is what applies pressure to the bobbin for winding.
good luck!
Posted on Jan 31, 2009
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
Why the bobbin wont wind correctly
My Brother has another spindle to wind the bobbin. Be sure to thread the thread through the two loops. I wind the thread around the bobbin a little and then start the machine. I find that using the cutter on the bobbin spindle helps to hold the thread on place.
Jul 06, 2014 | Baby Lock Ellure
My bobbin wont wind
you tell nothing, so let me guess
you could have wrong bobbin spool
it may not be inserted properly
your thread is just slipping because it isn't tight on the spool
you haven't engaged the "wind" drive
is the machine running but not winding? have you disengaged the main feed spool?
are you running motor at top speed?
Jan 01, 2013 | Singer Sewing Machines
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Threading the bobbin
Threading the bobbin - winding thread onto the bobbin.
Position the new empty bobbin onto the vertical bobbin rod next to the end wheel. Click the rod to the right to engage drive. Hold the outer end wheel with left hand, and rotate the inner wheel anticlockwise by about a 1/2 turn (it stops) this removes drive from the foot and needle mechanism.
From a spool of thread on the top, thread to a loop/post on the left on the top. Then back to the bobbin you want to wind. Thread through a hole from the inside-out. Hold the thread vertically above the bobbin while you depress the footswitch to start winding. Let go when it's turned a few times.
Move bobbin shaft left, and tighten end wheel after winding enough.
Fitting bobbin-
Move footplate towards you, insert bobbin in hole so that bobbin rotates anticlockwise when thread is pulled, then pull thread into the fine notch towards you. After this position thread away from you, and slide the footplate closed.
To start / load thread. Hold the end 3" of the thread through the needle behind the sewing foot. hand crank towards you to sew first stitch in air. This should retrieve the lower thread - which you can catch with a handy pair of scissors. Then pull both threads rearwards - ready to sew.
Jun 11, 2008 | Singer 5050 Mechanical Sewing Machine
Bobbin won't wind
Dec 23, 2007 | Sewing Machines
Euro-Pro 8260 Mechanical Sewing Machine Logo
582 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
