Question about Lexmark X125 All-In-One InkJet Printer
Paper wouldn't go in or out. I pulled it out but
Paper wouldn't go in or out. I pulled it out but it left a piece inside and says system error. I cannot figure out how to open the printer to get the piece out. Lexmark x125
    Genius:
  • 1,087 Answers
Here's an article in the Lexmark website on How to Troubleshoot a Paper Jam or Misfeed on a Lexmark X125. Just click on this link: http://bit.ly/bfgVWv. Hope this helps.
Posted on Jul 15, 2010
Says paper jammed i pulled out still says paper jamed
When you removed the paper did it tear or it came out in one piece.
If not there will be a small piece of paper left inside and this needs to be removed.
Apr 15, 2012 | Canon Office Equipment & Supplies
Hello, printer(esp5250) showing this mssg: "printer error. remove access cover. clear all paper. attach cover. press ok to continue. " done this about 15 times even tho there is no trapped paper....
There can be a piece of paper left <broken> somewhere between the gears inside the printer.
Try to partial dismantle the printer <remove the covers> and look inside, maybe you will see that piece of paper.
Dec 10, 2010 | Computers & Internet
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Error code E-04
I would check that there is nothing inside the paper feed system. The smallest piece of paper might cause a jam. Take the inks out and give the printer a good shake then put inks in and try again.
IHave you had a jam recently and pulled the paper out to clear it?
Jan 10, 2010 | Epson Stylus CX6000 All-In-One InkJet...
How do I fix a paper jam? I have a piece of paper that went in slightly sideways, and now its jammed. It's almost halfway in, so I'm afraid to pull on it in case it rips and pieces are left. Is there way...
You won't be able to make the printer work backward and push the paper out. Start by powering OFF the printer (unplug it if necessary). Then look to open up the front/top/back as appropriate to clear the paper jam. Frequently, if you pull straight and carefully (slowly), the paper will come out in one piece and solve your problem. If any pieces are left inside, remove them all before attempting to power ON the printer. If in doubt as to clearing, read the user manual - troubleshooting section on clearing paper jams. Good Luck!
Aug 13, 2009 | Brother HL-2040 Laser Printer
Grabbing the paper pulling it in at the left hand side
1) Try to adjust lateral directing limiters for paper.
2) See attentively inside device no there stranger subject such as pencil or piece of the torn paper. Use the lighting of the lamp or flash-light.
Mar 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Jul 20, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Mfc 655cw shows paper jam but tere is no paper jammed anywhere
what error code do you receive? Is it 30 only or does it toggle between 30 and 50 (watch some more 5 minutes!).
Anyway, two solution for this named errors:
1. Only error 30:
There IS some paper piece left inside the printer. Mostly could this be found on the very very left side (seeing from front as in normal use). Open scanner and have a good look into the edges. You will find a small piece of paper left there.
2. 30 and 50 (toggling)
See here same issue:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge browser window to see pic some what better).
Apr 15, 2008 | Office Equipment & Supplies
Lexmark X125 All-In-One InkJet Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
