Question about Maytag Washing Machines
We have a commercial maytag front loader and the front panel will not light up to say it has power, then there is power to the plug? What can fix this problem?
  • 6,784 Answers
HI. You have not included your entire model number in your initial post. This is very important to include. Every unit is designed differently, therefore, a proper model number will be required. With that said; You have stated that there is power reaching the unit. This will basically isolate the main control device as the lone culprit. Please provide a valid model number, asap.
Thanks...
Posted on Jul 15, 2010
I have a Maytag 3000 front loader. It looks the wash is done but I cannot open the door
Unplug the power. Wait 2 minutes, then reconnect the power. You should be able to open the door.
Alternatively, you can UNPLUG the washer and remove the bottom front service panel. Carefully reach up along the inside of that front panel and pull down on the manual release tab that is on the bottom of the door latch assembly. You should then be able to open the washer door. If this doesn't work, you will need to call Maytag for assistance.
Apr 19, 2017 | Maytag Washing Machines
Is there a filter on this model
Of course. The filter is located in the pump behind 'front' bottom panel. Disconnect power, remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Be prepared for a lot of water, catch it in something to prevent more work. Clean the filter from any debris that prevents water from draining out properly. Front loaders hv filters, top loaders don't. Don't forget to click that you are helped!
Oct 18, 2014 | Maytag EPIC MFW9700S Front Load Washer
Commercial maytag front loader starts high spin when money is put in
It's A You Drain Pump is bad. What a guy! He did not know that!? Replace the drain Pump and it will a Happy washer again!
Jan 19, 2014 | Maytag Washing Machines
Maytag Neptune front loader makes loud popping noise, shuts off, and trips circuit breaker. Plus, can't get the door unlocked to get the clothes out.
follow this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
Jul 10, 2013 | Washing Machines
My maytag is making and odd noise on the spin cycle.
The is probably a broken suspension part... on front loaders it would be the shock absorbers located underneath the drum.....remove the bottom part of the front panel to access them...on top loaders it will be a broken spring... these are much harder to access and fix.. the top must be removed and then many times the back and/or sides...hopefully you have a front loader and it is just the shocks...very easy fix then.
Feb 04, 2012 | Maytag Washing Machines
Maytag front loader washer, control lock light is on. how do i turn it off?
You have to hold down the lock button on the control panel for 3or 4 seconds it should turn off
Sep 12, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing Machine agitates only
maytag front loader washing machinne the drum agitates but does not spin
Feb 10, 2009 | Maytag MAH6500 Neptune Front Loading...
I need to know how to get into my maytag washer.
it all depends on what type of maytag washer.
  • assuming it is a top loader, and is a standard maytag washer then you will see 2 screws on the front panel almost at the bottom. take these out and you will be able to take the whole front panel off.
Aug 01, 2008 | Maytag Washing Machines
Maytag MAH21 - main motor won't run
Please check microswitch block door/ Best result change this microswitch on the new. If terminal is shot - longered on wire.
Rashid Moscow (arashid@yandex.ru)
Dec 19, 2007 | Maytag MAH21PDD Commercial Front-Load...
Washing Machines Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
