Question about Gateway FPD1975W 19" LCD Monitor
Monitor not waking up
When my monitor hibernates for a long period of time (over night) I have trouble waking my monitor up. I move the mouse, hit the keyword, turn the monitor power on and off but nothing works unless I take out the power cord and plug it back in.
Any solutions to this?
Thank you,
  • 26 Answers
SOURCE: Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Posted on Feb 25, 2008
tantong
  • 138 Answers
SOURCE: Monitor will not turn on- was working fine a week ago!
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went gray or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
mdsaeed67
  • 849 Answers
SOURCE: monitor says no signal
the cable has two ends, see the other end
Posted on Oct 27, 2008
  • 732 Answers
SOURCE: Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Posted on Dec 30, 2009
  • 1584 Answers
SOURCE: Last night I hit the power button to turn off the
Needs to got to monitor repairer.
Posted on Mar 11, 2010
Turn on my monitor from sleep mode
It should turn on when you move the mouse around a bit. Otherwise, it is in hibernate and you need to push the start button for 1 second or so to wake up the computer.
Mar 01, 2015 | HP Media Center m7657c home PC - RC640AAR...
Monitor has gone to power saving mode
Hello, The reason your monitor switched to power saving mode is because the operating system on your computer told it to. A computer left on and unattended is programed to sleep/hibernate after usually a short period of time. Without going to in depth, There are stages of sleep and after time the hibernation deepens. However, moving the mouse or pressing a key should take it out of sleep. Microsoft has a support page for this issue: http://support.microsoft.com/kb/266283 Good Day
Feb 12, 2014 | LG Flatron W2242TQ-BF 22" LCD Monitor -...
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
I have an old Dell computer monitor that is hibernating and can't be waked up. When I try to wake it, I get an Information Box that says "Monitor is in Power Save Mode. Activate by using the...
click the mouse, move it about or press a key , if that doesn't wake the pc up, then press the power button for 1 sec, that will wake it up
Apr 14, 2011 | Dell Computers & Internet
How do I wake up the monitor when it goes to sleep when not used for a short time.
slapping it around usually works. "just a joke!"
tapping a few keys on your keyboard and moving the mouse will usually wake the monitor from sleep mode.
Nov 11, 2009 | Office Equipment & Supplies
My monitors sleepy
Go to the control panel on the computer and look for power options. On the first page there is power schemes, make sure the scheme is on "Home/Office Desk", below that make sure everything is set to "Never". If you don't want the computer "Hibernating", Go to the "Hibernate" tab and uncheck the box. Hit apply and OK. No more sleepy monitor.
Sep 11, 2009 | LG L1919S LCD Monitor
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Computer remains in sleep mode to conserve electricity
This is a known issue in Vista. Computers going into hibernation and then not waking up. I believe it was fixed with the Service Pack 1 distribution, but I'm not 100% certain.
I would recommend that you go into the power options from the control panel and disable hibernation. You can tell the computer to turn off the monitor and the hard drive after a period of time, but just don't leave hibernation enabled.
Mar 13, 2009 | Computers & Internet
My pc sleeps and I don't know how to wakeit except to turn it off and re start it what can I do?
If it is in standby mode hitting any key on the keyboard or moving the mouse should wake it up. If it is hibernating pushing the power button should wake it up.
Jun 18, 2008 | HP Computers & Internet
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
