Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Please help me. I have a Mitsubishi Mr. Slim air conditioner. Yesterday, following a roofing job on my flat roof house, I heard a whooosh of water coming into my closet which backs onto the unit with the air grilles. The main unit is up on the roof. Water poured into my closet and made a mess. I turned off the air conditioner but need to know what to do next. Thanks for your help. It is 95% here in Mtl. today!
    Problem Solver:
  • 12 Answers
It sounds as if this water is coming from your air handler, correct? If this is the case, your drain tube is clogged or not draining properly. You could drain the condensate tube into a bucket temporarily, but this needs to be repaired properly.
Posted on Jul 21, 2010
Securing unit to roof structure
Assuming you mean a pitched roof
you need a roof mount kit from you local AC supplier
they are a generc item
Apr 14, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. silm 42000 btu air conditioner in door working outdoornot working
mr. slim air conditioner good brand. wall type or casset type (Roof model)?..
1) may be your control processing unit (PCB) damage.
2) Refrigerant gas leaking. low pressure switch off.
3) Compressor not working properly.
4) This is 3 phase model may be Ac power not correct.
my opinion call Service person.
Mar 22, 2011 | Mitsubishi Heating & Cooling
I need an evaporator control board for Mr. Slim Model MS 18 NN Where can I order this item ? Please help. C.J. Leslie
Here you go
http://www.expertappliance.com/mitsubishi-mr-slim-parts.html
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Jan 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Have a Mitsubishi Mr. Slim. Power light is flashing, vanes are working, but fan & heat not working
your roof/side of house unit is not working
Please rate/vote this response thanks
Dec 20, 2010 | Heating & Cooling
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
My Mitsubhishi Mr. Slim MSZ-A17NA 1 is drippping water on the inside. I have turned it off for now. What should I do? We're in Mississippi and it is a hot day! thanks
Hi!!
Make sure the unit is leveled, there is a drain hose coming from rigt side of the unit goes through the wall to the outside and down, this hose is probably clogged up.
Go outside the house and look for it. there should be some tubing wrapped in insulation going up to the roof top and a drain hose coming down. You can try to unplugged it from the inside using a wire clothes hanger or you can blow air from the outside end into the unit, you only need a small blow and you can use a flexible funnel or a piece of garden hose and some tape to do it. if you are going to do this make sure to drain all water from unit using a towel to avoit splashing. This works all the time.
Don"t forget to rate this post. Good Luck!
Jul 01, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
May 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
159 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
