Set TXN3075WHF set does not come on need schematic of power supply
  • bweddings Jul 20, 2010
    Thanks waiting for the email
  • 10,594 Answers
Let me know your email address to send you schematics of TXN3075WHF
Below is image of service manual page.
Thanks.
Posted on Jul 15, 2010
How do i change fuse for txn3075whf
Inside of the TV usually near the power cable on the PCB. If you don't know what you're doing get it repaired.
Dec 29, 2012 | Samsung TXN3075WHF 30" TV
Samsung dtb-h550f need value of R28 in power supply
Download the schematic diagram to your set from here. It will have the details you want.
Jun 08, 2012 | Televison & Video
Sansui SV-3715LCD, I switch off the unit at the wall socket, when I plugged it in the next day there was no power, not even the LED indicator light on the front of the LCD activates. I checked the plug...
Continue to check--every set has a standby power supply that powers the remote circuit to turn set on and it runs 7/24 if set is plugged in.
Never a good idea to turn set of by taking the AC away--it can cause micro problems(micro processor).
The standby will provide voltage to the micro (low like 3-5 volts) and if a mechanical relay is there it also supplies it.
if NOTHING try to isolate that area in the main supply as they usually combine the standby in with the main power supply.
You may need to search for a schematic with GOOGLE (good luck on that) but if total dead begin there.
Worst case if problem is in standby you may have got the eprom or the micro when this happened
If further questions I will try to help.
Mar 23, 2012 | Televison & Video
No power, red led doesn't light. Power cord is
Manufactureres usually keep their schematics to themselves however you may be able to contact them to purchase a new power supply.
Jan 23, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
Dim monitor
Hi
You just bought a new power supply for the monitor? Did you set the B+ voltage to the correct settings. Rebuilt power supplies for CRT monitors are not set correctly at the factory. Use your schematic to determine the proper B+ and then set this under load.
Thanks
Jul 21, 2009 | Toshiba Tekbright 15" CRT Monitor
Proton LCD Power supply
Here is a link for you! The problem could be capacitors with high ESR values won't provide adequate pulse energy transfer! Do you have any freeze spray? Spray the caps, then retry to see if the PS starts up. An ESR meter would be a good tool for future use!
https://www.google.com/#q=fsp194-3f01+power+supply+schematic
Apr 20, 2017 | Televison & Video
Schematics or diagram for a 480W PSU
I need a schemetic diagrm D15-1013/diablo ATX 250w Power supply
Thanks Louie.
Dec 18, 2008 | Computers & Internet
Bad picture
Hi Dan,
It sounds as if you have a bad filter capacitor in your power supply. Check the main filter caps rated at 150 volts and above. It's likely one is leaking and need immediate attention. I hope this helped. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Samsung TXN3075WHF 30" TV
Toshiba
do you get a flashing led if so how many times?
this is a post from someone else:
Thought I would report my finding with this set. Maybe someone else is experiencing the same problem.
The set would turn on with no picture. No high voltage - no raster. By turning up the volume, you can hear some noise in the speakers. This set has many fuses and they all checked out ok.
I located some schematics on the net for the previous generation set - 40H80/56H80. I could not find any site with the 50H82 schematics without paying. The 40H80 seemed to match the 50H82 fairly closely. I checked the horizontal output transistor with a scope and found no signal. I traced the signal back to a board on the signal schematic called the DPC module. No HOT signal was being generated by this module. Per the schematic, I checked the voltage supply pins at this module and found everything ok except pin 6 which is supposed to be +12V. I traced this back to the power supply connector and found voltage (pin3 of 8 on BB30). Since I got the set for free and I was feeling risky, I shorted the +12V at the connector to pin 6 on the DPC. I got a small spark and the set shutoff, but I could hear static which indicated that the HOT briefly same on. I shorted out the connection again and turned the set on. This time is powered up and came back to life. I've run the set for a couple days so far and it appears to be working great.
I may have gotten very lucky, or I may be shorting out something that is not supposed to be shorted. I would really appreciate it if someone who has the real 50H82 schematic could check the connection between DPC pin 6 and the power supply connector BB30. If this is a real connection, I have to assume that the trace burned out somewhere. It vias up and down all over the place and is very hard to follow.
Dec 11, 2007 | Toshiba 55H70 55" Rear Projection...
Wont turn on
Hello zang,
This denotes a problem with the switching power supply or the high voltage power supply. what is happening is the safety relay is being actuated by the shutdown circuit. Any number of things can cause this proble but more then likely the problem is in the high voltage power supply section and or its associative circuitry. The switching power supply and the high voltages power supply have very dangerous voltages and I would not suggest that you work on the TV set unless you do have a background in electronics. If you do not I would suggest that you take the TV set to an electronics shop for repairs. If you do have a background in electronics, you will need the following items:
1) A schematic diagram (to know where voltage and signal test points are located and to have a reference of the levels.
2) A multimeter (to measure the DC voltage levels on the TV Set)
3) An oscilloscope (to measuer the AC voltage and signal levels in the TV set and compair them to the values in the schematic)
4) A signal generator (to generate a reference signal for troubleshooting)
I hope this helps,
Shuttle83
Oct 11, 2007 | Panasonic CT-32HX41 32" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
