Question about Samsung Televison & Video
Panel s:n: cn07Bn4400339ASE38Z252043R.B ,Icb 80 is burned we can't see the reference
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
The tv probably burned out
Posted on Jul 15, 2010
Where is the factory amp on 09 hhr ls
Preliminary Procedures
Remove the rear seat. Refer to Rear Seat Replacement.
Remove the left quarter lower trim panel. Refer to Quarter Lower Rear Trim Panel Replacement.
Remove the rear compartment floor stowage compartment tray. Refer to Rear Floor Trim Plate Replacement.
Rear Seat Nut (Qty: 6)
Caution: Refer to Fastener Caution in the Preface section.
Tip
Roll the seat forward enough to get access to the nut that attaches the center seat belt assembly to the floor.
Tighten
45 N·m (33 lb ft)
Rear Seat Bolt (Qty: 3)
Tip
• Adjust the seat forward or rearward to access the bolts.
• Remove the plastic trim pieces to gain access to the nuts.
Tighten
45 N·m (33 lb ft)
Rear Seat Assembly
Remove the quarter upper trim finish panel. Refer to Quarter Upper Trim Panel Replacement.
Remove the rear compartment trim panel. Refer to Rear Compartment Trim Panel Replacement.
Remove the floor trim plate. Refer to Rear Floor Trim Plate Replacement.
Quarter Lower Trim Finish Retainer (Qty: 2)
Quarter Lower Trim Finish Panel Assembly
Procedure
Remove the cargo tie down loop anchor plates and bolts.
Remove the rear passenger seat belt guide.
Disconnect the rear passenger seat belt so that the trim panel can be removed around the seat belt. Refer to Rear Seat Belt Replacement.
Pull the trim panel toward the inside of the vehicle to disengage the retainers.
Tighten
9 N·m (80 lb in)
Quarter Lower Trim Finish Panel Retainer (Qty: 5)
Sep 11, 2018 | Cars & Trucks
Wear is the factory amp on a2008 chevy hhr
Radio w/uw5 has no amp , radio w/uq3 has amp .
Callout
Component Name
  1. Remove the rear seat. Refer to Rear Seat Replacement .
  2. Remove the left quarter lower trim panel. Refer to Quarter Lower Rear Trim Panel Replacement .
Amplifier ***** (Qty: 4)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
9 N?·m (80 lb in)
Radio Speaker Amplifier Assembly
Tip
Disconnect the electrical connectors.
Apr 16, 2016 | Cars & Trucks
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Jan 10, 2015 | 2008 Buick Enclave
Activation code for Pastel v11 education pack
You can change your system date to an old date. When you open pastel the company will not be available in the OPEN A COMAPNY window. CREATE a NEW company. Use COPY ANOTHER COMPANY option and copy the last company you worked on. You will be able to proceed with your lesson.
Mar 14, 2013 | Computers & Internet
My Honda CBR 954 will not fire up after dropping on the left side; it spent over a month at a certified Honda shop before they gave up on it. We went throw the wire harness, and already changed the ICB,...
Any Honda dealer that spent a month on your bike and had no success is a Honda dealer that I would avoid ever going to a second time. A bike needs gas, air to burn the gas, compression to make use of the burning gas, a timed spark for igniting the gas, and a path for the burned gas to exit the cylinder. Go to a different dealer. Tell them to check the fuel delivery, air intake, compression, spark timing and spark quality, and exhaust system. Fuel delivery and spark are the most likely source of the problem. This ain't rocket science. I think you will find the first Honda dealer's "mechanic" is totally incompetent. Simply hooking up a code reader should point the mechanic in the right direction.
Mar 13, 2011 | 2002 Honda CBR 954 RR Fireblade
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Manual - I need directions on how to use the Sony ICB-100
http://esupport.sony.com/US/perl/model-documents.pl?mdl=ICDB100&LOC=3
Jun 10, 2009 | Sony ICD-B100 Digital Voice Recorder
Bunn ICB-DV Infusion brewer does not power up
If you go to www.bunn.com, you can download the manual for your brewer in pdf form. These manuals explain how to test each electrical part of the brewer.
Oct 21, 2008 | Bunn ICB-DV Coffee Maker
Televison & Video Logo
41 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
