Question about 2-Way Car Alarm System w/ Remote Start
How i can progam the tach
I have a alarm already installed on my car, but i can't starter it, because i dont know how program the tach
    Problem Solver:
  • 7 Answers
You don't have to program the tach brother.. just hook the wire they tell you to use to the Negitive coil wire or to the tach its self. the Alarm is self learning. when it see's a signial it will determine if its a 6, 8 or 4 cyl and what the RPM's are and thats it man bob;s ur uncle..! Even if you don't have a tach the - coil wire has the signial everytime the coil fires thats what your seeing on the tach the coil fireing ccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc00cc
Posted on Jul 16, 2010
  • STEVE Mar 21, 2011
    this didnt work , hhow do i prgram this damn thing to my monte carlo 2001
Crank but no start
If your truck already has a factory alarm you will need to get a pass module installed to bypass the factory alarm.
Jan 28, 2014 | 5301 LE 2 Way Car Remote Starter System
Remote start starts car and dies off after few seconds
try having the cpu reset using a code reader as you may have two systems operating in conflict that is causing the problem.
Jul 29, 2013 | Audiovox Prestige APS997C Alarm/Remote...
I recently installed a python 872 on my 2002 maxima. Now everytime i use the remote start and open the trunk the car shuts off and restarts in about 10 seconds. I had other dei alarms and never had that...
It's possible that the installer has the engine monitoring option programmed for voltage and, the unit sees a drop in voltage when operating the trunk...causing the remote starter to shut down. If so, try programming the unit for tachless instead or, hook up the tach wire.
Jun 10, 2011 | 872 Responder LE Security Remote Start
I have the alarm system hooked up, i have the remote start hooked up as well but its not turning over and starting the car. it flashes 7 times, (parking lights) do i need to install the starter inhibit...
The seven flashes of the parking lights when you attempt to remote start is the tach signal not being programmed. If you hooked up the tach wire already, turn the ignition on, press and release the programming switch three times. Turn the key off, press and hold the programming switch and start the car. Continue to hold the programming switch while the vehicle runs. The parking lights will be flashing while the tach is being programming. Hold for at least 15 seconds for a good signal. This allows the engine to "smooth out" into a normal idle rpm.
If the parking lights are not flashing, the tach is not being programmed. You may have skipped a step during the set up for the programming or, you have the wrong tach wire. If you went to a injector or coil wire, it is the uncommon wire. This means that there exists two or three wires at the injectors/coil packs. One or two of the wires are the same color at all of the injectors/coil packs and one wire is a different color at each injector/coil pack.
Mar 03, 2011 | APS787 Prestige Remote Start and Security...
Remote starter doesn't function
if the battery was replaced or any terminals removed, you may have lost the tach programming for the remote starter. Goto http://www.bulldogsecurity.com/bdnew/installmanuals.asp and look for the remote start unit you have in the manuals and it will tell ya how to reprogram the tach memory.
Jun 29, 2010 | Bulldog Remote Starter & T-Harness Kit for...
1999 dodge durango wont start
may work may not...on older cars when the starter went bad and the car wouldn't start you could tap the starter with a long screwdriver or hammer lightly and the solenoid would engage and start the car but you need to get it home or to shop cause it wouldn't work again..if you try this and the starter engages then the starter needs to be replaced if you haven't already tried..if the lights are flashing when you try to start the vehicle then o would say its prob a malfunctioning alarm system..try to diengage it by pulling fuse for alarm..don't know if you can though..check the starter...good luck
Apr 12, 2010 | 1999 Dodge Durango
Alarm goes off when trying to remote start my o 06 malibu was up!!!
i hav same problem chaged battery noticed battery holder was loose so i soldered it very carefully everything works fine xcept remote start alarm just goes off like when you push the panic button not sure what happened dont think i shorted out the circuit board in the fob if engine light is on this car wont start via remote these remotes must b progamed by dealer or pro shop prob using what they call a tech II computer to remote start you hav to press lock button 1st even if car is already locked i figured this out pess and hold lock button then press start alarm dont ring and the car starts.
Jan 13, 2010 | 2005 Chevrolet Malibu
Have installed the Bulldog remote starter in my 2005 jeep liberty. I have to hit the button several times to get it started. I have already changed the jeep's battery.
There is some sort of a feedback to tell the starter if the unit is running - make sure you have the 'tach feedback' connected. There are settings for it to run the starter for specific length of time, or for it to know that it started by the tach feedback. Check your users' manual.
Dec 29, 2009 | Remote Starter with Keyless Entry
After installation my starter has been replaced twice (within 2 months)- the only 2 times I used the stop button
It is possible that the Tach/RPM monitor circuit (an integrated system that informs the RSM [remote starter module] that the engine has started and is running) is malfunctioning or is not properly connected, hence the continuous effort of the RSM to start an engine that is already running, causing damage to the cars starter and possibly other circuits and/or wiring.
Return the car to the installer and have diagnostics ran on the Tach/RPM monitor circuit.
Your system may have a hardware or programing choice that will allow you to decide between a  tached or tachless operation, depending on the model that is installed.
I hope this helps... Good luck
Feb 22, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Jan 17, 2009 | 791XV The 791XV is a 2-way Security and...
2-Way Car Alarm System w/ Remote Start Logo
431 people viewed this question
Top Performance Teknique Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Performance Teknique Vehicle Part and Accessory Expert? Answer questions, earn points and help others
