Ice maker no longer working. Its turned on, but no longer makes ice. The water dispenser does work properly (water supply OK). However, I no longer hear the water feed to the ice amker anymore (normally can hear the water when it runs).
Same problem. Please reply.Same problem. Please reply.
AnonymousJun 18, 2008
LG Side by Side Model # LRSc 26940 ST
Water supply continues to run over & freezers in the ice maker tray. Therfore, jamming the mechanism. Help !LG Side by Side Model # LRSc 26940 ST
AnonymousNov 02, 2008
Ice maker frozen and H2O dispenses correctly. Made ice for about 6 months.Ice maker frozen and H2O dispenses correctly. Made ice for about 6 months.
AnonymousNov 06, 2008
unit stopped making ice, unit is less than 2 years ,has had several problems , lg what junk, whole kitchen is lg, one problem after another, Used hair dryer to make sure no ice in line. Still no ice, turned power off a couple of times to reset ? no luck.
I have a cracked supply line for the water dispenser, how do you replace them?I have a cracked supply line for the water dispenser, how do you replace them?
AnonymousMar 30, 2014
Water is on but not making cubesWater is on but not making cubes
You can't post conmments that contain an email address.
If your refrigerator's ice maker is working, but no ice is dispensing through the dispenser, there are a few possible causes and troubleshooting steps you can try:
Check the ice chute: Make sure the ice chute is clear of any ice obstructions. Sometimes, ice can get stuck in the chute, blocking the flow of ice to the dispenser. Use a plastic utensil or a straw to clear any ice buildup or debris in the chute.
Inspect the dispenser mechanism: Open the dispenser area and check if any part of the mechanism is obstructed or damaged. Look for any ice blockages or misaligned parts that may be preventing ice from being dispensed properly. Clean or repair any issues you identify.
Verify the dispenser solenoid: The ice dispenser is usually operated by a solenoid that controls the release of ice from the ice maker. Ensure the solenoid is functioning correctly by listening for a clicking sound when you press the ice dispenser paddle. If you don't hear a click, the solenoid may be faulty and require replacement.
Check the dispenser motor: The dispenser motor is responsible for activating the auger that pushes ice through the chute. If the motor is not functioning properly, it may need to be replaced. Test the motor by activating the ice dispenser and listening for any humming or buzzing sounds. If you hear the sound but the auger is not turning, the motor may be faulty.
Inspect the ice bucket: Ensure that the ice bucket is properly installed and seated in the correct position. Sometimes, if the bucket is not aligned correctly, it can prevent ice from flowing through the dispenser. Remove the ice bucket and reposition it securely.
Check the water supply: Make sure the refrigerator has a steady water supply. If the water supply is interrupted or the water filter is clogged, it can affect the ice production and dispenser functionality. Check the water line and replace the water filter if necessary
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned
off. Here's how to check. Look for a wire along the right side of the
ice maker that looks a bit like a coat hanger. If this wire is in the
raised position, the ice maker is turned off. On some units you simply
lower the wire to the down position to turn the ice maker on.
On others,
you lower a small red plastic lever to lower the wire. If the wire is
in the proper position check the freezer temperature, it should be
between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the
ice maker may not produce any ice.
Check your door seals and thermostat,
repair/replace as necessary.
Sometimes the valve on the water line becomes plugged and can no longer supply water to the refrigerator. The other options are that the ice maker could possibly not be supplying voltage to the solenoid valve on the rear of the fridge, or the solenoid valve could be bad itself.
It is possible that the water valve behind the refrigerator is either defective or the wire connection is loose. Also check the fill tube where the water comes in and see if there is ice blocking the fill tube. Since it's under warranty, have it serviced by the LG warranty to resolve this issue.
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
will not make ice water works fine
