Question about Hitachi 42HDS69 42 in. Plasma Television
Once you turn on the TV you get a quick glimpse of the show then it goes to black. The little blue "on" light blinks. I tried to change the input to DVD and I cant do that either.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Maybe a capacitor burned out.
Posted on Jul 15, 2010
My tv has sound, but no picture. When I turn it on the blue light blinks eight times and the screen is black. What is wrong?
Hi Tammy,
Please check the INPUT of your TV by pressing INPUT, SOURCE or TV/VIDEO on your TV remote. Once you press one of those ( that was on your TV remote ) you should have INPUT lists on your TV screen. All you have to do is select each one on the list until you get a picture ( normally input is TV ). Hope it helps.
May 05, 2014 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Flash screen lights, then goes black, comes on with restart.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 19, 2013 | Televison & Video
Television comes on for a second and then screen turns black but tv still on
Does the OSD (on screen display) come up when you hit the menu button? If so try changing the input to the one you need.
Apr 04, 2012 | Televison & Video
Turns on and off by itself
If this happens on all inputs and you have disconnected the power and reconnected it and that didnt fix it.
Sounds like a logic board issue problem is LG only warrenties tvs for 1 - 2 yrs.
Jun 16, 2010 | LG 42LC2D 42 in. LCD HDTV
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Mitsubishi ws-55515 light blinking
Sounds like the remote is not programed correctly or the input sources have been changed.
Call the cable company and complain that it worked before they came and shoud work afterwards.
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
105 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
