Question about KitchenAid KUDD01SSSS Compact Dishwasher
Dishwasher cuts off
My client has been having a recurring problem of this machine cutting off after starting the cycle. The indicator light will turn on, and she has to push that to get it to restart. This has to happen a number of times before it will finally finish. I also noticed a small amount of water in the bottom. Any ideas...?
  • 1462 Answers
SOURCE: dishwasher doesn't drain
suspect not draining properly all the time. if plumbed into the trap under the sink, then check there is no blockage there. (quite common) . hold drain pump into a bucket so you can see the rate of flow. hold the bucket about 3ft off the floor. if poor flow, then you either have a blockage at the pump or the pump is faulty
Posted on Apr 30, 2007
jsrock516
  • 5911 Answers
SOURCE: Dishwasher wont finish cycle
I have experienced this problem before and it turned out to be the main control board in the console. Not a cheap fix, either. The control boards are not serviceable, and can run over $100. Sorry, I hope I was of some help.
Posted on Jul 10, 2007
  • 3 Answers
SOURCE: Maytag Quiet Series 300
Sounds like a thermal fuse that is a less than $20 part. remove the top 6 screws in the door that hold the plastic front panel on. Behind that is a circuit board and a white flat 1" square fuse with two wires going to it. make sure power is off at breaker. Test with an meter to see if any current is going thru. If not, that is most likely your problem, and just follow the fuse replacement kit instructions carefully, including putting the new wires on the new fuse like they say. Otherwise, the original wires going to the fuse will blow it too.
Should take about 20 minutes.
Posted on Feb 12, 2008
  • 1314 Answers
SOURCE: dishwasher won't work
i think they been charging you for the control panel and replacing the fuse there is a fuse in the control panel go to appliance parts store and tell them you need control panel fuse for your model get two or three then remove the panel and replace the fuse
Posted on Sep 09, 2008
skrbin
  • 121 Answers
SOURCE: dish washer does not drain after the cycle is complete.
check drain hose and drain pump.End of drain hose must be in same
level with machine.Try it.
Posted on Feb 15, 2009
Bosch SGS6302 Dishwasher failing to complete cycle
Does it heat properly? Was that the cause of the power failure?
Mar 17, 2014 | Bosch Dishwashers
Dishwasher mdb675 problems
I have the Maytag 675 type 777-0 that is not functioning correctly. The start button is flashing on and off and water is in the bottom of the tub. Just before this happened I would cut the power completely off the washer turn it back on and it would start the cycle by hitting any buttons at all. I called out a serviceman and long story short it was going to cost $411 for the service call and repair. Can you say new dishwasher?
Aug 26, 2012 | Maytag Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
My blanco bfdw6x dishwasher has the folowing symptoms - power on, 30 min wash cycle set, after pressing start cycle button the machine sound likes it tries to start, but then cuts out and the digital...
Ours does the exact same thing. We pull it out and tip it which drains some water on the floor and then it works. It is something a technician told us ages ago, something to do with a water level switch underneath.....but its driving us mad. We have to do it on a regular basis. Does anyone know how this can be fixed more permanently. thanks.
Sep 03, 2010 | Dishwashers
Eco light comes on when I switch on machine but can't change programme and it doesn't work some water still under filter
This indicates water in the base, there is a polystyrene float that operates a cut off switch if water leaks into the base, this could be caused by a leaking pipe connection, or simply by water getting by the door seal and eventually having enough volume in the base te operte the float switch, try tilting the machine backwards if water comes out of the basethen this should cure the problem, but if it recurs fairley quickly you should have the hose connections checked for tightness, can be accessed from the base.
the dishwasher should be isolated from the supply first base tray is secured by 6 screws, the float switch is attached to the base so care should be taken when removing the base tray
Apr 23, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My dishlex 760 cuts out during the cycle, there
I have the same problem.
Initially, the only problem was the dishwasher was not taking in water. Told to replace solenoid - which i did.
Now the problem is exactly as you explain. Sometimes you have to keep trying after 20 times and then it goes.
Any ideas on what the problem was ???
Mar 03, 2010 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Sep 19, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
KitchenAid KUDD01SSSS Compact Dishwasher Logo
46 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
