Question about Sony STR-DE698 Receiver
Sony str-de698, unit keeps going to protect mode
Unit keeps going to protect mode
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony STR-DE698 7.1
in Sony receivers Protect display shows problem / fault in Amplifier output area. Qualified technician can repair the damage.
Regards,
Posted on Sep 05, 2008
  • 92 Answers
SOURCE: goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
Posted on May 20, 2009
ginko
  • 19396 Answers
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
I have rewired my receiver and the SOny str-d565 keeps shutting off. Is this fixable or should I just get a new receiver?
This unit most likely has shorted output transistors. The unit is entering protect mode which will prevent further damage to the unit. Expect a parts cost in the $40 range for this repair.
Dan
Feb 11, 2011 | Sony STR-D565 Receiver
I couldn't able to switch on my sony str db930 .when it was use it say me protecter.
Check all of your speaker connections... usually the PROTECT cuts in when speaker wires get crossed or you have blown a speaker.
this PROTECT message also shows if the amp chip(s) have blown in the unit
Sep 01, 2010 | Sony STR-DB930 Receiver
Protect Mode
need replaced power ouptup .assy
Apr 28, 2010 | Sony STR-DE698 Receiver
Shuts down in protect mode
disconnect all the speakers and turn it on. if it does not go into protect mode, then youve got a bad speaker or wire. good luck
Feb 10, 2010 | Sony STR-DE597 Receiver
I need help my sony str dec 445 keep flasking the protect on the display
first check for any loose speaker wire in the back as this will cause the unit to go into protect mode if the bare speaker wire is touching, if thats not the case then there is a problem with the unit internaly and would be hard to tell whats wrong with it without looking at it.
Dec 11, 2009 | Sony STR-DE445 Receiver
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Goes into protect mode..
May 17, 2009 | Sony STR-DG520 Receiver
Sony str-d715 flasses protector
May 03, 2009 | Sony STR-D700SS Shelf System
Sony STR-DE698 7.1
Regards,
Sep 04, 2008 | Sony STR-DE698 Receiver
Open Questions:
Sony STR-DE698 Receiver Logo
271 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
